zippitta wrote:I was saying that wider tires are almost always made out of a softer compound. Mainly due to the afct that wider tires are usually made for increased performance. So do me a favor and reread my posts.
I read your post one more time, but some stuff don't make sense.(nothing personal)
1) Wider tires are not made for increased performance. If you put softer tires, the same size as before, they are going to wear out quicker. So you will be getting 6 months tire life out of them, intead of 12. And no one likes to change the tires, or pit that often during the racing appilcations.
When you make the rubber softer, you have to add more rubber to compensate the wear rate, in order to get adequately same amount of life out of your tires.
In order to increase the tire life you can:a) Make the tire thicker on the bottom, more rubber, more thread. But that will create thermal issues. As the heat will build up on longer travels and highway speeds. You are risking the meldown of the tire. This is the reason why slick tires in racing situations are made of thinner thread, to avoid heat buildup.
b) You make them wider, wider means less downforce per squire centimeter, so less wear per centimeter squire. Also thermal buildup is not an issue, since you have more area to dissipate the heat.
zippitta wrote: You miss undestood what I was saying. I wasnt saying that the sidewall itself was what was giving the tire the traction.
That has nothing to do with the point of this thread. This thread talks about the non-dependency of friction on the contact area. Why did you bring it up in the first place??(no need to answer)
I am not even going to spend time to answer Magnes and navysnail, since they don't have correct knowledge in this topic. Bunch of teenagers.
Oh and also, this thread doesn't discuss thread design, grooves for water channeling. That is another topic, which I don't think I should bring up.(so much hatred already )
Here is another thing to make you guys hate me harder:
Having less mass/weight will not improve your braking distance. As in less distance. No it will not!!
Also, in creasing the weight of your car during the winter(IE putting weights on the rear for rear wheel drive automobiles) is a good idea. It will not improve your braking, but it will improve traction on your DRIVE WHEELS.
Modified by sanioll at 2:25 PM 11/29/2005
