Z24 drop in replacement (not Z24i)
Adverse Effects
Car: 1987 Nissan Navara 2WD 2.4L Z24
Base Standard Cab Pickup 2-Door styleside
5 speed manual
dose any one know of a drop in replacement motor that is a bolt in? i want to keep it a 4 banger as well
i would like to convert it to a Diesel motor but dont want to change all of the drive chain to do it so if it carnt be Diesel another petrol motor will have to do
i have been looking now for about a month but carnt seem to find much info on fitments
any help will be much appreciated
Adverse Effects
5 speed manual
i have
1987 Nissan Navara (3/1987 japan made) 2WD
chassis # NGD21-001331
Model # NGD21FM
2.4L Z24 (S) 2389cc
points(hall effect replacement installed)
singel spark dizzy
carby
Long wheel base
Diff / Trans Axle FS5W71C CA39
5 speed manual
ok so after going on 3 months *sigh* (my head hurts) there are 3 contenders TD27T4, TD27Ti or TD27ETi
TD27T = 1 wire almost drop in (need to change bell housing)
TD27Ti = 2 or 3 wire drop in (need to change bell housing)
TD27ETi = donor car wiring harness + computer +++ drop in (need to change bell housing)
TD27T = 5 to 7 hour install + exhaust
TD27Ti = 10 to 12 hour install + exhaust
TD27ETi = 15 to 22 hour install + exhaust
TD27T = around 9Km to Lt
TD27Ti = around 11Km to Lt
TD27ETi = around 12 to 14 Km to Lt
is that about right?
now a few things i haven't been able to work out
do i need to find a manual donor so i can use the bell housing , flywheel , clutch? or will a Auto donor do and use the Z24 bell housing , flywheel , clutch
:poke:
JarredH
Car: 1991 Nissan D21. 2WD, FS5W71C. KA24E.
1995 Nissan D21 SE. 4WD, FS5R30A. VG30E.
You'd have to see if the bell housing will mate to your engine and transmission to know if it'll work. So, either bring it with you, find out the information on the web, or you might be able to get away with making a cardboard template to see. Now, I'm no master mechanic and I've never had to deal with clutch and flywheel things, but I'd imagine as long as the flywheel and clutch have the same bolt pattern and size between the two engines, it should work, right? If anything, you can just buy a new flywheel and clutch just to have new parts for many Km's of use, and (hopefully) there'll be no worry about if it'll fit or not.
I'd think you can try the Z24 stuff and if it doesn't work, what's another trip to the bone yard?
Again, I'm no master mechanic, just giving some though into this.
Really though, with enough planing, money, time, and fabricating, you can fit anything into that truck. People do put LS3's into Miatas, after all! :crazy:
Did Nissan ever sell the Diesel Pickups down under? All I can remember is that if was a European thing. Maybe you can find one of those engines. My year truck (91) Came in Diesel over the pond, I know that. And it does have the same transmission code you posted. Maybe the Diesel shared a common transmission? Then you can have Diesel without changing the transmission, or possibly anything at all. Just make sure you get as much harness and engine control stuff you can get if you don't feel like doing it all by your self. Sure, it's possible, but do you really want to do all that work?
There's my thoughts. Good luck on this, I wanted a diesel truck, too.
Adverse Effects
5 speed manual
i will be trying to get a full SUV as a donor but parts here are stupid prices
just a small sample
NISSAN TERRANO II 2.7 TD27 TURBO MAN PUMP ENGINE 97 TO 99 (24609) $2,365.00
Nissan td 27eti turbo diesel motor box and dash cluster $2,000.00
this is why i am trying to find out about the bellhouseing and and internals before i buy a full car
as for money i am on a fixes small income (disability) but spending $2K now and not having to get my z24 rebuilt for a 3rd time in 3 years and the realy bad fuel consumption of the z24's i am getting about 6Km . Lt the diesel should get almost 2 times that and be bullet proof
JarredH
Well, based on that 27eti link's information about that engine and transmission, and the pictures, it has the bell housing there, ready to go. Ask them if it has the clutch and flywheel, too. With that, you'd get an engine and transmission ment to go together for the price.
hardbody-diesel-td27-conversion-t482612.html
http://www.nissan-navara.net/viewtopic. ... 5&p=290560
http://www.navara.asia/archive/index.php/t-17223.html
Looks like the bell housing is different, according to that last link. Now I wonder what housing will fit the two together.
JarredH
Also, 6Km/L? My ka24 is getting about ten and a half, city driving. Maybe look into getting one of those engines.
Adverse Effects
5 speed manual
thanks for thos links
yes it would seem i need to get the manual version and that sucks because there 3 times the cost and like 1 in 10 is manual here hmmmmm
so its going to be like finding rocking horse sh^t
JarredH
Well, you'd only need the manual version for the bell, and possibly flywheel and clutch. Otherwise, manual or auto would work for the engine. Maybe see if you can find just the bell somewhere? Kinda hard to source parts for Australia when I'm in the States, so sorry I can't help more. I just don't know where to really look, ya know?
Adverse Effects
5 speed manual
hehe i know the feeling mate :-)
i am starting to think the same way with getting an auto but then i am having trouble finding a manual flywheel LOL
i can find a clutch kit and i have seen a few manual boxes but there asking stupid $ for them (almost as much as the car)
its all good i'll have to just keep plugging along at it
the BIGGEST problem is the 1 and only Nissan only wrecking yard in Brisbane (my home city) burnt down 2 years ago and depleted the stock of reasonable priced 2nd hand parts and shipping here in Oz is stupendously expensive so not worth shipping form other places in Oz
JarredH
Damn man, that blows. I guess you could ask the place selling the gearbox if they'll trade yours for theirs, and if they possibly have a flywheel laying about you can get. Maybe just negotiate a lower price? A little Social Engineering can go a long way!
Adverse Effects
5 speed manual
OMG I SCORED BIG TIME
91 TERRANO TD27T auto BUT (only 161,000 Km on the clock) he had bought a manual box flywheel clutch and pressure plate and all other items needed to convert it to manual and was going to build it up for his son
his son whined about it being not the car he wanted
dad's reply? sold the LOT to me for $1000 and told the son to earn the money for a car him self
WOO HOO ! ! ! ! ! ! :dblthumb: :woot: :mike :dance :chuckle: :shifter: :BnB:
about $3000 worth of gear
Adverse Effects
5 speed manual
and the fun has started
i have decided it will be easer to get the motor out by takeing off the body :wtf2: :crazy:
here are just a few picks of the first day
step 1 get a donor
step 2 get to the motor
step 4 put the body off to one side so you can take more parts off it later and move the frame out of the road
here are some more pics
google+ images
If there is anything you want me to take pics of specifically let me know ASAP because this could all go real fast
Adverse Effects
5 speed manual
well motor is out and on a stand i bout from SUPERSHEAP AUTO less than 24 hours old and the motor only sitting on it for about 10 min
this could have taken my toes off
rated at 450Kg only had about 280Kg on it
then this happens
more google + images
Adverse Effects
5 speed manual
i went back to the store i got it from and got them to open a few others of them on the shelf and ALL had the same defective part/metal and they left them on the shelf to
JarredH
That's a little sketchy. I'd just weld it all up and keep going.
Good job on finding that donor, what a bratty kid! I didn't complain when I came home to my truck, gave my mum a big 'ol hug and drove the truck around! Hope the kid leaned something from this!
