What's up guys? Fist I have to say that I own a Rogue not an Altima. But since we're a big happy family
I thought I might get some help here...
I'm a total newbie when it come to wheels, so here are my choices and I will appreciate any friendly advise.
1) Altima Rims (18", Rim Width -> 7.5", Bolt Pattern (Number of Holes) -> 5, Bolt Pattern (Pitch Circle Diameter) -> 114.3, Offset -> 45mm).
2) Touren TR3 (18", Rim Width -> 8", Bolt Pattern (Number of Holes) -> 5, Bolt Pattern (Pitch Circle Diameter) -> 114.3 and 120, Offset -> 20mm).
3) Touren TR3 (18", Rim Width -> 8", Bolt Pattern (Number of Holes) -> 5, Bolt Pattern (Pitch Circle Diameter) -> 100 and 114.3, Offset -> 40mm).
Now with the Rogue's I have Specs:
215/70-16 [stock S] (16", Rim Width -> 8.5", Bolt Pattern (Number of Holes) -> 5, Bolt Pattern (Pitch Circle Diameter) -> 114.3, Offset -> 40mm and Center Bore Size -> 66.06mm).
So, what do you guys recommend? Should I take the safe side and go for Option 3 or Can I go with Option 1 without any risks or worries? Option 2 is there just in case... I planning on using 225/55-18 tires on the rims I get.
Thanks in advance for any help provided...
