Water Control Valve Location With Images
Blindaviator
Car: 2001 Nissan Pathfinder LE
Coolant Temp Sensor (for ECU) & Thermal Transmitter (For Dash Gauge)
Water Control Valve (203 Degree Thermostat)
atro
Car: 2003 pathfinder
what are the symptoms of a bad water control valve?
PathyPop
Car: 2003 Nissan Pathfinder LE 4x4
Look at the location of that PCV valve, a routine maintenance item. I can imagine the Nissan engineers designing it with easy access, but then Nissan corporate tells them "What are you thinking? Move that PCV valve to the back and under the manifold so our dealers can rack up a couple hundred of after warranty labor charges".
Seriously, couldn't put it in a more difficult location.
yeldogt
Car: 02 Pathfinder 4X LE (X2)
It was one of the reasons to always use the correct coolant -- the valve (thermostat) and cross over tube are expensive to fix if any issues.
AlanAZ
Car: 2003 Infiniti QX4 RWD
Thank you. Excellent photo documentation of engine under the intake mani. And good on you for using OEM parts.
Look at the location of that PCV valve, a routine maintenance item. Seriously, couldn't put it in a more difficult location.
Agreed. I previously spent considerable time looking for the PCV valve, as I like to replace it at 100K mls, I seem to recall that it is more accessible on the 3.3L engine. Why make the change for the worse? (On my two Toyotas, they are right up front, and are metal.)
EdBwoy
Thank s for the contribution. This is definitely sticky-worthy!
