they are not the same as in one went into a fwd car and one went into a rwd car,g35paul wrote:i recently just blew my motor in my s/c g35 and its now getting a fresh motor,so im going to have a spare vq and im going to be throwing it in my s13.... i was wondering why u guys go with a fwd vq motor, they r not the same as what ive been told by sharif at forged.... just wondering
but they are the same as parts interchange when switching platforms IHE,cams,upper oilpan, most sensors, you can use a rwd trans.
the fwd motors have the same cams, but static ignition is 10:1 (IIRC) instead of 11:1 (Again IIRC probably discussed in this thread too)
Getting a FWD block will cost you anywhere from $150 - $1000 at the MOST
where as a rwd block starts at $1200 and goes up from there.
in the end switching out parts like the oilpans, intake, headers, it will still be cheaper than purchasing a RWD block.
the most hp i have seen on a fwd block is like.. ~500 so i dont know if they will be as good for higher hp like the rwd blocks have been seen at
