Type-X J5/J4 ECU - Redtop harness
johnnys180sx
Car: 240sx
hey everybody i have a redtop wire hardness that i broken, now my buddy has a stock blacktop s13 wire hardness will it work the same? i mean after i put the ka plugs will it work?
CoupedUp
Car: 1993 Coupe
There are some changes to the blacktop harness in comparison to the redtop harness. I'm not 100% sure on the pinout changes near the ECU but I am aware of some.
Someone else will chime in.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Pinout changes on the ECU plug? I didn't think there were any since I've successfully ran S13 blacktop ECUs on redtop harnesses
CoupedUp
Car: 1993 Coupe
I did some more research, if its a 96-99 S13 Blacktop J5 ECU a few pins changed. If it is 91-95 S13 Blacktop E5 or E6(Auto) ECU than you're good to go.
If you have the J5 ECU, Ill do the research for you, I like helping people...haha. Im sure its minimal pins and maybe 3-5 solder joints.
Hijacker
'94 F-150
That's what I thought. Thanks Sean!
Tulsa_S-13
Car: 1991 SR 240sx
CoupedUp wrote:I did some more research, if its a 96-99 S13 Blacktop J5 ECU a few pins changed. If it is 91-95 S13 Blacktop E5 or E6(Auto) ECU than you're good to go.
Correct, although I've never heard of an E6 ECU. Your Redtop harness will work with the J2 / J3 / E4 / E5 without any changes to the ECU pinout. These ECUs were found in S13s ranging from 1991 to 1996. The Type-X S13 Blacktop used the J4 and J5 ECU which, of course, have a slightly different ECU pinout than the non Type Xs.
Here are the ECU pinout differences-
Changes to other connectors were also made:
I'm assuming your friend has the wire harness for the early S13 Blacktop (non TypeX), as the TypeXs are harder to come across.
Here is a link to the pinouts for both the J2/J3/E4/E5 and J4/J5 ECUs. To make sure which harness your friend has you can simple compare the wiring coloring to that of the pinouts.
Complete pinout diagrams for KA/RB/CA/SR series ECUs:http://www.az240sx.org/tech/Pinout/
johnnys180sx
Car: 240sx
wow guys thanks for all the help! so it look like the hardness is a CODE E5 so is should work thank guys
slow s13
Car: cars, photo, music
there are some differences in the O2 sensor circuit, if I recall its the power wire for the heater part of the sensor is different.
schanne
Car: 93 Hatch-Sr20
I have a J4 ECU and had to repin about 6 wires. It's really easy to do, just need a little patience. If you have the J4 or J5 ecu with a different harness you will have to repin or it wont even start.
schanne
Car: 93 Hatch-Sr20
This will help-zerothread?id=297604
