Here's a few links.
ultimate-wire-tuck-guide-t403443.html
post4990854.html
One of the things you can do to make your engine bay cleaner is to put your injector harness under the intake manifold.
It's a bit time consuming though, since you also have to unplug a few stuff like the MAF and other plugs on that side.
Another thing you can do to make your engine bay neater is removing emissions stuff.
Once you remove your EGR, Carbon Canister, and other things, the only line for your FPR:
Then you just need to plug a pipe that comes out under the throttle body
There is also this upside down "V" hose on the manifold, you can plug it at the source (if the manifold is off the car), or the hardline it's attached to under the throttle body.
If you ever need vacuum line pictures, here's a good thread.
1991-1993-240sx-vacuum-line-identifying ... 81398.html
