True Pig Build
Bumnah
Car: 1992 240SX, black. Bone stock.
Your door panels remind me of RS door panels for 911s.
Cool stuff. I'd like to see the results of your twin charger setup.
freerebel1993
Car: 1990 240sx ka24e
awesome build dude
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
hey you should post more pics of how you did that little gauge pod for the af r that isa cool little idea i might have to copy
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
I wish i could...my computer crashed with those on it....but what i did was, Went to home depot and found a piece of pvc type tube...it was black. Note the gauge didnt fit in, way too tight. I took a file and shaved off some of the inner diameter of the pvc. I then traced the diameter of the pvc onto the bezel. With a dremel I cut it out. Then I took and positioned the pvc in the angle i wanted and secured it with jb weld stick....I used the jb weld stick to shape the entire thing. its kinda like clay but hard as a rock and doesnt crack like bondo. make sure you get the back of the bezel and pvc. then after i got it to the ruff shape i wanted i took regular jbweld, the 2 part mix, and spread it over the area like a glazing putty. I let it dry and then sanded it. Let the whole thing cure for a few days before painting it. sorry no pics
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
yeah i did a custom 3 gauge set up and avcr where the radio goes. used jb weld to do that. but this looks very nice.
martins_240sx
Jb weld is like baking soda...you can use it for anything
martins_240sx
only other one i have
martins_240sx
so me and my buddy (s13 with ls1 and ford 9inch rear end rocking 335 street slicks, lifting tires on demand) were brainstorming on my pully setup...it has been decided that im going to make an engine plate that will bolt in 3 spots on the timing cover/block and 1 to solid mount the alternator. it will be reverse fashion meaning the pullies and belts will be hidden. Im gonna mock up the board template today and then move to the aluminum and then take it to the water jet to cut it out of 3/4 plate...
motoman399
Car: 98' wrecked (RHD coming soon) 240
well that will be interesting. get some pics please. also if you wanna post pics/video of your friends s13, it sounds bad a**
martins_240sx
he was on here long long ago...he got flamed for asking info on ls swaps...he never came back..seriously one of the cleanest 240s ive ever seen. looks like it rolled off the show room floor. drag radials in back fully tubbed and caged with skinnies up front...i crap whenever he hits the gas....he just got back from afghan and now talks of twin turbo ls
motoman399
it sucks when people do that s***. some people just are looking for info, and dont know how forums work.
you should tell him to come back and be like what now bishez haha
martins_240sx
yeah. He jokes around about doin that from time to time...Im sure he will once he starts his twins. the thing is already a monster. it will still light of those 335 like they are 205s...i think he is around 440 ish...beautiful car...ill convince him to come back. Im sure all my local buddies on here have seen or heard it drive by
motoman399
you said it will pull the wheels off the ground? thats impressive and i wish i could afford 335's lol
what is the color of the car?
martins_240sx
yeah he can pull em..not crazy wheelie style but the wheels definetly come off...its a hunter green...not oem color. he needs some new ones...iirc he is rockin mickey thompsons.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
I've seen that thing rolling around. Indeed, it's a monster.
Milkmusic
Car: 97 Chevy Lumina
Just read this and all i can say is HOLY SHET!
martins_240sx
thank you...I just ordered my m8X1.25X150mm bolts..these things are long...when the come in ill mock up the plate in card board then masonoite then mdf then the final aluminum sheet to take to the water jet to use as template for the 3/4 plate aluminum.
7x13
Car: '89 240SX Hatch (Sold)
Amazing Build
:dblthumb:
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
thanks for the pic man. your budies car sounds sick. there was a time i was talking about going ls1. and twin turbo but i would give some serious props to some one who does it first
martins_240sx
small update...this is very rough of the final outcome but you can see what im doin
motoman399
HMMMmmmmm..... interesting.. lol
Milkmusic
A SOHC doesn't sound so bad anymore
martins_240sx
thats what im trying to tell everyone....why sohc? why not? less complicated and willing to take the boost
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
The belts are setup better and the oil pump is easy to replace. Love SOHC.
martins_240sx
well i was trying to assemble my head and i got as far as installing my solid lifters. for some reason they are binding up. i cannot rotate the cam. i had this same problem on my last head. i returned the lifters and he sent me new ones. i have them all the way backed out but they just wont allow the cam to turn. also when i un did the jam nut the unit just spun inside the lifter. i will try to contact omar on monday to see what his opinions are.
martins_240sx
nevermind about my previous post....blonde moment
motoman399
lol ^^ what did you do?
martins_240sx
well...let me just say that i was really questioning my knowledge on the very basics of engine operation....all the schools all the certifications and i really looked like an idiot...good thing i was the only one around....
little teaser.....
those valve cover t's are gonna be cut down and powder coated the same color as the charge pipe...black chrome maybe
motoman399
i bet the valves were hitting the pistons.... haha. i tried to put my engine in my toyota pickup the other day. i put the clutch/flywheel on before the dust plate haha. oops. so i took it back off and fixed it.
dont worry mistakes happen.
martins_240sx
no it was even worse...the head was off. i was trying to rotate the cam and it wouldnt move. I was thinking what the heck is going on with this lifter having no clearence. turns out that that lifter was trying to open that valve so there would be no clearence. I couldnt rotate the damn cam because these springs are so damn tough...long story short...I dont know why but i was thinking that there should have been clearence the entire rotation of cam...which offcourse is impossible. 6 hours later i went back and face palmed myself :facepalm: It was early in the morning
