IMH »
https://forums.nicoclub.com/imh-u110135.html
Wed Dec 31, 1969 5:00 pm
[user=223]Montezuma[/user] wrote: [quote]Buying my extra floor shift transmission would still be cheaper than the other options laid out here thus far.[/quote]
Not really since a 320 floor shift trans is the same as a 520 floor shift trans-bottom cover 4 speed. Both of which are quite different from a 320 column shift trans-side cover 4 speed. No other trans will be a direct 'bolt-in' if your 320 started out with the column shift trans. It also requires the mounting plate, later clutch, starter, and front driveshaft yoke, and modification to the rear transmission mount. Your truck (Montezuma) must be a 65. A few changes were made at the factory to the 320 in order to change to that trans. What trans did you replace it with? I went through all of this when I swapped out my E1/column shift for a J16/200sx dog leg 5 speed. If you're going to do this swap, you might as well use the same trans I did. It's the same amount of work.
