Transmission update and forest air
ProverbPsalms
Car: 2006 M35x - Graphite/Black, Journey, Tech
2011 M56x - Black/Java - Deluxe Touring, Premium, Tech
Hey all,
I noticed my forest air doesnt work all the time now, it was working when I first picked up the car no issues at all, I went to change the air filter, and found out there was no air filter in the cabin, I had one installed, now I cant turn on the forest air?
Also I have been reading on these forums about a transmission update and ecu relearn, what should I do? My car is a bit laggish and jump.
M37xfan
Car: Traded in 2012 Infiniti M37x
I know that forest air will not work when outside temp goes below 32 degrees
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
this is true It won't engage blow 32
DredM56
Car: 2011 Infiniti M56 2004 Subaru Wrx STi
I just recently noticed that now that it got really cold where I am.I assumed that was the issue was going to search and here's my answer.
ProverbPsalms
Thank you, that explains it, it is freezing here in Toronto.
What about the transmission update? I am going to try the ECU update
1080Rider
Trani update is ITB12-021. You can ask your dealership about it. I was charged for a suspension update in my old volvo V70R, so you dealership might want some $$$ to load it... I don't have any experience w/ the infiniti dealerships though.
PostalsQ
Is this trans update secluded to you 5.6 fellars?
1080Rider
The one I posted was for the 37's I think. I'm not sure if they use the same trani in both...
armybrat
Car: 2012 M56x with Tech Package (sold)
Custom 2-1/2" X-pipe exhaust with OEM sport mufflers
HPS intake hoses
Uprev tune
1080Rider wrote:The one I posted was for the 37's I think. I'm not sure if they use the same trani in both...
No they are different, and also it depends if your car is AWD or RWD. The M37 transmission's are actually more expensive.
walt1227
Car: 2011 Infiniti M56S
I just had my oil changed right before Thanksgiving and asked about the transmission update. The dealer told me it would be $120 if there was one out there for the M56S.
DFW2011M56S
Car: 2011 M56S
walt1227 wrote:I just had my oil changed right before Thanksgiving and asked about the transmission update. The dealer told me it would be $120 if there was one out there for the M56S.
There was one for my 2011 M56S RWD. Very noticeable difference in my car. ECU and TCU both are updated per the service bulletin.
ProverbPsalms
Is a service bulletin same as a recall? Is that free to do?
DFW2011M56S
Car: 2011 M56S
ProverbPsalms wrote:Is a service bulletin same as a recall? Is that free to do?
Service bulletins are not free unless you are under factory warranty. You pay labor for the update or correction. It is simply information regarding fix's for various well known problems.
Nielsio
Car: 2010 Nissan Fuga Y51
Is there any way to do the updates without a dealer? Reason I ask is that i don't live in the US however do own a 2010 Fuga (Y51) 3.7 model... Don't really have a dealer to go to here so would be interested in knowing what it would take to be able to perform the update
Ilya
Nielsio wrote:Is there any way to do the updates without a dealer? Reason I ask is that i don't live in the US however do own a 2010 Fuga (Y51) 3.7 model... Don't really have a dealer to go to here so would be interested in knowing what it would take to be able to perform the update
You'd need a CONSULT device...and that would just be the beginning. You'd also need the update itself which I can pretty much guarantee you Infiniti would never give you.
