Swap: Infiniti M56 engine into 07 M45
crweaver
Car: 2007 M45
I'm about to put a 2011 M56 motor and transmission in my 07 M45. I'll be sure to keep notes of any issues as well as what will work
and what will not. I'll have the help of Paul & Brennan from the FB Group, so this is gonna be kinda interesting.
Reason: Title
milto0n
Car: Infiniti M45 S
Take pictures. Godspeed *salute*
LIBRILZ
Car: 1990 Nissan 300zx
2007 M45 Sport
whoa, this is super interesting, has this been done before?
EdBwoy
Congrats on the big, brave leap!
I understand why you were burned out on the 4.5 though.
Best of luck
Ilya
LIBRILZ wrote:
Wed May 02, 2018 3:33 am
Yes. Maybe not that EXACT combo, but similar:
http://www.superstreetonline.com/featur ... initi-m35/
crweaver
Car: 2007 M45
EdBwoy wrote:
Wed May 02, 2018 6:48 am
Best of luck
Yeah I'm like WTH! I put in another 4.5 two weeks ago and still have this complete 5.6 sitting here. The first 5.6 i got was water damaged but after putting in the 4.5
another 5.6 came available with low miles and after dry/wet compression testing, this one is solid! So i've made up my mind to
go ahead and give it a shot.
milto0n
Car: Infiniti M45 S
Any updates on this?
EniGmA1987
Car: '06 Infiniti M35 Sport
This sounds pretty interesting. I have been wanting to put a newer, higher gear count trans in my car for a while. The spacing is just too far apart for great performance in my old 5 speed. I hope all goes well, Id like to see how things go so I can use some of your experience on my own stuff.
crweaver
Car: 2007 M45
Anybody tell me how to post pics to this thread? I'm in the process of prepping the 5.6 now. So far the 4.5 alternator. power steering pump and ac compressor bolts to the 5.6 easily. Only had to modify the PS fluid reservoir bracket to mount it. The 4.5 belts will fit with a little elbow grease but could stand to be about half an inch longer. being that the starter is under the intake manifold on the 5.6, i'm gonna replace it along with new valve cover gaskets and plugs while its still out of the car. 4.5 will be coming out of the car next week soon as we pull the uprev licenses off of the ecu.
EdBwoy
crweaver wrote:
Sat May 19, 2018 2:24 pm
Anybody tell me how to post pics to this thread?...
Here are some options:
how-to-post-pictures-on-nicoclub-compil ... 18411.html
EdBwoy
How is this project coming CR?
crweaver
Car: 2007 M45
Waiting on the harness to back. Im gonna have a drive shaft made cause i cant use the shaft from the m45 or the m56! both shafts are the same length but the trans and diff ends are different which puts the carrier bracket off by like 4 inches. other than that we're moving at a slow pace..lol
EdBwoy
As long as you're still moving, that's encouraging.
What's being done to the harness - unwrapping the M56 wiring to fit in place of the M45 one? Or is it tweaking the M45 harness to adapt to the M56 differences?
Post some pictures if you please, or send them to me and I'll share them here.
babycharm00
Car: 2008 Black M35S
babycharm00
:werd:
crweaver wrote:
Tue May 01, 2018 6:20 pm
Are you posting this on the fb group, if so which one?
LIBRILZ
2007 M45 Sport
Is this build dead?
Dxta
Car: Infiniti M45 sedan base sport
:slap:
EdBwoy wrote:
Sat May 19, 2018 11:17 pm
http://forums.nicoclub.com/how-to-post- ... 18411.html
I'm just wondering. Isn't there a simpler way of posting pictures here, instead of going through that link to keep reading and trying to post just pictures?
Can't an icon be created where you've for instance, POST PICTURES OR IMAGES BLABLA?
basjcksn2
Car: 2004 infiniti m45
did it happen .im late or new to site.
EdBwoy
Dxta wrote:
Sun Feb 28, 2021 12:49 am
:slap: ...
Lucky you. This is 2021 and Nicoclub now has a simpler way to attach pictures directly. There is an attachments tab.
See below:
Image 1
Image 2
EdBwoy
LIBRILZ wrote:
Thu Feb 25, 2021 4:18 am
Is this build dead?
basjcksn2 wrote:
Sun Feb 28, 2021 8:52 am
It did happen, and the car ran and drove. That is as much as was shared publicly.
I will leave it up to the OP to share whatever updates he wants to.
LIBRILZ
2007 M45 Sport
EdBwoy wrote:
Sun Feb 28, 2021 10:59 pm
Is this build dead?
Ah, that's great to hear. I wonder how this platform feels with the VK56VD. I'd be interested in what all was done or had to be done, just as far as using the 7-speed auto. Five gears isn't enough!
EniGmA1987
LIBRILZ wrote:
Mon Mar 01, 2021 6:46 pm
Ya I have long wished I could swap to a 7 speed transmission. Now though I am trying to find someone to swap in the new 9 speed trans. It is a Mercedes/Daimler 9G-Tronic that Nissan got a license for, built and sold as Jatco but it is a 9G-Tronic. Nissan put it on the newer Titan and now the Frontier. The Titan uses this VK56 engine this thread is about, so the new 9 speed is a direct mount to it. Who knows, maybe the OP will do an upgrade to the 9 speed at some point and show us pics :naughty: On the new Frontier, the engine is larger bore and stroke than our VQ35DE's, but otherwise a very similar block to ours. Which means the bell housing on the model designed for the Frontier should bolt on to our cars as well. Then the electronics would just have to be figured out.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
EniGmA1987 wrote:
Tue Mar 02, 2021 9:55 am
That won't be simple. The new ones all have electric IVT. :squint:
VStar650CL
Technical Expert
PS - The 9-speed won't exactly be a DIYer's paradise, either. It has a magnesium housing with aluminum fasteners. The latter are coated to keep them from binding galvanically, and they're on everything, even the valve body. Because of the coating they're all single-use, once the coating is broken they're thrown away. For all that, it only saves about 40 pounds of weight. :crazy:
LIBRILZ
2007 M45 Sport
Well the 7-speed was just interesting from the point of view of simplicity. The 9-speed is a whole other can of worms id assume!
LIBRILZ
2007 M45 Sport
OP, any update to this thread?
