Throttle position sensor question
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
If we dont get many leads we can start a new thread......
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
check the manifold vacuum at idle and 2500 rpm to see if the sucker is breathing. Could be really clogged up intake valves.
areznik
Car: Infiniti Q45 1994
BMW 335i Couple 2007
Something I noticed today. When I start the engine, the fuel pump gets REALLY laud to pressurize the fuel lines. It sounds like somebody is drilling into the metal. This lasts for about 5-10 secs. I don't know if this affects anything but it definitely sounds abnormal. Wes, we didn't hear this sound when I was at your place. But again, the fuel pressure was normal. This is a new present that my Q threw me today. Maybe it points to somethings ... . Any ideas???
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Check the vacuum, try a fuel filter. Has it been changed?Bad Knock sensors will make it slow, so will clogged EGR and dirty TB.
texasoil
'94 Infiniti Q45A
Did you check the TPS at differnet throttle positions? A faulty one will normally throw a check engine light, but? Clogged fuel injectors and cruddy intake valves will choke it down. What does the O2 sensor outputs look like--it is controlling or not.
Check the intake manifold vacuum--if the timing chain is a tooth off, the vacuum will be way low. If valves are clogged, vacuum may be OK at idle, way low at higher RPM's.
Ignition timing late will also drastically reduce power. I presume you have checked things like dragging brakes to rule them out. If engine is 'normal' in neutral, but sluggish in gear--look to brakes or transmission. Dragging lock up clutch in torque convertor chews up lots of power till it cooks.
areznik
TPS gives the correct voltages, the same as on Wes' car. So, I rule this one out. Both O2 sensors are new. I rule these out. On March I did air and fuel BG clean up service. Just five minutes ago, I disconnected the air hose from PCV and check with finger if its taking any air. I didn't feel anything at all. The rpms drop a bit and I block the pcv. It seems that its just not sucking the air?? Could it be bad timing - because after the dealership "adjusted" my timing this problem appeared. Also, the air hose before the PCV and the inlet where the PCV sits are wet in oil. It is normal??
Today I bought BG44K and poured it into the tank. However, now it seems that air is the problem. Any suggestions how to proceed?
texasoil
'94 Infiniti Q45A
ah ha! now we are getting to the bottom--the problem showed up only AFTER the timing was adjusted? well, that's the first thing to have checked.
Rule 1 if things get worse when something is 'adjusted' or 'fixed', it wasn't done properly.
Rule 2--See Rule 1
Put a vacuum gauge on it and check the vacuum (between the throttle plate and the intake valves. )
elwesso
2007 BMW M Coupe
Andre.. Go to walmart, or the closest place around here that has auto stuff, and get some SEAFOAM in the can OR marvel mystery oil (its the same stuff) and do the procedure just like I told you.....
squeefoo
1999 Infiniti I30
Is it a new fuel filter or not?
squeefoo
1999 Infiniti I30
Is it a new fuel filter or not? BG 44k won't clean out the fuel filter if it's clogged.
elwesso
2007 BMW M Coupe
His fuel filter is just a few months old, and not many miles.....
squeefoo
1999 Infiniti I30
It was never mentioned. Clogged converter ? How the H*** did I double post !!!???
Aus94Q45
Car: 1994 Q45
The PCV valve may have some oil and deposits. Overall this sounds like a timing problem to me. Engines will run flat or lose acceleration and top end with improper timing. Couple of thoughts -- the knock sensor codes jump out at me here. That has to be taken care of for the integrety of the other diagnostics. THey adjust the detonation. Further Dennis has stated that Q's go flat with bad knock sensors. Also, have the under plenum hoses been replaced? Lots of vacuum leaks to be had. Also, even though the fuel filter has been replaced recently, it can clog quickly. ALWAYS start with the easy stuff. Also, "after the dealership "adjusted" my timing this problem appeared" says to me (a) bad timing adjustment; (b) they left off a hose or some other connector. Have the timing adjusted again.
elwesso
2007 BMW M Coupe
I think aus is on to something
His plenum has been removed about 3-4 times in the last 2 years..... Thats puts a lot of wear on the hoses...
When the KS go bad it doesnt make it run this bad...
I think maybe a KS inspection and maybe a really good plenum clean are in order...
Q45tech
Look at the CAS top front: the position adjustment slot is roughly 3/4" long that's 45 degrees of adjustment range.
15 degrees BTDC is roughly when the left of the screw shows 2/3 and the right space is 1/3 exposed.
I can imagine a tech might get the timing wrong by 1,2,3 degrees but not enough to show your symptoms. They see the CAS all the time [when checking for corroded connectors] and they know what looks about right.
Because it is difficult to loosen the 3 screw bolts without double swivels it doesn't just get randomly adjusted because of the special ingition transformer necessary to couple a timing light to the system.
areznik
Just took it to local Nissan dealership. Tech adjusted timing, he said it was a fraction off but nothing serious. We drove the car, and he connected consult tool to it. He said that everything is nearly perfect. Tps is working properly, air fuel mixture is excellent, and no error codes. He told me, that to him it seems that my Q is just fine - yeah right, you can tell he never drove Q before.
I replaced PCV - no change. I was wondering, I have bosch platinum 4 plugs. Should I switch to NGK, I mean can it make the difference?
squeefoo
1999 Infiniti I30
Huge difference, I didn't think so until I did it. It had Autolite Coppers in it, when I got the car, it seemed okay, but the difference for me was huge. For the right plugs at the right price: Wes. To check for vac. leaks squeeze the hose like the FSM says, that worked for me too.
squeefoo
1999 Infiniti I30
PS ! Bosch +4 plugs are very bad for this motor, do a search.
Q45tech
Bosch +4 the destroyer of Q.......let us know how many electrodes were burned off [4x 8=32 chances]. Not every time but often enough to be scarey.
texasoil
'94 Infiniti Q45A
until you check the intake manifold vacuum at idle and steady 2500 rpm you will not be able to determine if valves are crudded up or cats plugged.
Fuel air mix at idle being OK does not mean its OK at other conditions. Plugged fuel filter will pass enough for idle, not enough for any power.
It always pays to check basics first--filters,hoses, timing, intake vacuum--then hunt for other subtle failures like plugged cats and electronic stuff based on the fundamental test results. Phsyics of engine performance have not changed in 100 years, only the precision of adjustment of parameters to optimize combustion.
areznik
The tech drove with me having the consult tool with him connected at all times. So, we checked idle as well as driving under cruise, then WOT ... . Now that I read more about Bosch plugs, I suspect that plugs are probably the cause. When I put the Bosch, I didn't know about NICO, it was almost two years ago. We will see, I hope plugs will do it. I am going for PFR5G-11, which is according to owner's manual are the standard NGK plugs.
Q45tech
With the Consult you look at [data record] the MAF voltage WOT from 4,000 thru shift or redline.Those numbers from 3.000 rising to 4.440 volts tell me everything when matched with rpm and injector [11ms> 10ms] and timing advance [22-28].
areznik
Great news! BG44K is a miracle! Even though my Q is not in top shape by performance measures, it has definitely improved for the last two or three days after I added BG44K. I can't be more happy! I will pour another can in the next refill to see if this will cure the whole problem. I will also replace spark plugs with OEM to avoid potential complications. So it seems that fuel system was dirty or intake valves as some of you suggested.
It was such a pleasure to wash my Q, now that I know that my babe is getting back to shape. I will be out of states for two months, but I will post more info when I come back and drive a little bit more with the second can of BG44K and new plugs.
Don't want conclude anything yet but there is a light at the end of the tunnel. :D
elwesso
2007 BMW M Coupe
Youll definitely wanna do a seafoam treatment.. Go get some seafoam and do the treatment...
areznik
Wes, I remember you told me to disconnect that breaking hose and then spray that foam. Can you repeat the whole procedure again step by step? I want to make sure that I do the right thing.
How is your sub, have you connected it already?
elwesso
2007 BMW M Coupe
For the seafoam, it comes in a liquid form (not aerosol, like BG44k)... It helps to have a small funnel, ideally we should have done it at my house since I have these little tiny funnels that fit perfectly inside the booster hose...
The other way you can do it is pour it into a small cup or something like that and stick the hose in the fluid a little bit at a time.. YOU DO NOT WANT TO FLOOD THE ENGINE OUT..... its easiest to have someone inside the cabin running the engine at 1500rpm or so..
Make sure the car is at operating temp first....
So the procedure would be1. Take off the brake booster hose, the one on the booster near the master cylinder......2. Figure out how your going to get the fluid in there, by one of the things i mentioned...3. Start the engine, run it up to 1500rpm (have a helper) and slowly add the seafoam through the hose... Dont let the enigne die, and it it struggles let off and then go again.... Under no circumstances should the engine die4. As soon as you add the whole can, immediately shut off the engine and let it sit for a while (20 mins or so)...
After this, take it out and run the poop out of it... Many redlines thorugh 1st and 2nd gears to blow all that crap out of there..
Be warned, you may not want to do this in a residental area, as it gives off a TON of smoke, so if someone would be offended you might go somewhere else.....
I have my sub installed but im still having problems with it, apparently my connections arent very good... :(
