From everything I've ever seen posted...the story is you can't on an AWD.m35squadron wrote:I was wondering if anyone has installed staggered wheels on there M35x model?? And if so have they had any problems with the diff's?
I am curious as to the basis for your opinion. Do you have personal experience with an AWD car with proper spec'ed staggered wheels that caused any problems with the car?DashingMax wrote:Yes, anything is possible. Do you really want to risk breaking your differential?
I know, but if one wants to avoid any risk or the hassle of matching the diameter, this would be another option...lawman12 wrote:You CAN stagger and use AWD....
again, I would love to know the factual basis for these opinions... I think it would be great information for the Mx owners to have this info if based on true factual experience that proper staggered wheels have damaged the infiniti AWD system.szhosain wrote:Folks, please DO NOT stagger the wheels on a Nissan/Infiniti ATTESA system. Doing staggered wheels will almost guarantee that the front and rear rolling diameters will be different. You simply cannot get close enough with tire selections to reduce the difference to where the the system will not be unhappy and increase the aging and wear on the system - if the difference is high enough, you will damage the AWD system.
The bottom line: stick with the stock wheels (at 18", they are not that bad, guys!) or replace all four wheels with the same identical wheel ... including identical tires. Check your tire pressure for uniformity often as well.
Z
Just another option is all.
Actually, I have seen this done often enough with the Lexus AWD and the Audi Quattro. You can actually get within .013 of an inch in one case I have seen. You can't argue that little of a difference with affect the ATTESA...you can get more than that with a small difference in tire pressures.szhosain wrote:Folks, please DO NOT stagger the wheels on a Nissan/Infiniti ATTESA system. Doing staggered wheels will almost guarantee that the front and rear rolling diameters will be different. You simply cannot get close enough with tire selections to reduce the difference to where the the system will not be unhappy and increase the aging and wear on the system - if the difference is high enough, you will damage the AWD system.
Z
It is not that simple. Simple calculations of the tire diameter from the tire size (as is commonly done using many simplistic calculators on the Internet) is not good enough a method to work in this situation. The ATTESA system is different from the other car mftr AWD systems, by the way, and is sensitive to these issues.rgb129 wrote:You can actually get within .013 of an inch in one case I have seen. You can't argue that little of a difference with affect the ATTESA...you can get more than that with a small difference in tire pressures.
Perhaps a good one to follow, but pointless to stagger the wheel then!M4T5 wrote:If you do use staggard wheels, use the same size tire on all four corners. Not sure what size tire will look good and fit well that way, but it is only a suggestion. Probably a good one to follow.
Remember that the ATTESA system is not a continuous all-wheel drive system ... it transfers torque as it detects speeds differences. This system can get quite erroneous results (switching in and out the electric coupler between the front and rear axles when not warranted) when the speed differences are caused by factors other than what is supposed to be.DESCRIPTION
• Electronic control allows optimal distribution of torque to front/rear wheels to match road conditions.
• Makes possible stable driving, with no wheel spin, on snowy roads or other slippery surfaces.
• On roads which do not require AWD, it contributes to improved fuel economy by driving in conditions close to rear-wheel drive.
• Sensor inputs determine the vehicle's turning condition, and in response tight cornering/braking are controlled by distributing optimum torque to front wheels.
NOTE:• When driving, if there is a large difference between front and rear wheel speed which continues for a long time, fluid temperature of drive system parts becomes too high and AWD warning lamp flashes rapidly. (When AWD warning lamp flashes, vehicle changes to rear-wheel drive conditions.) Also, optional distribution of torque sometimes becomes rigid before lamp flashes rapidly, but it is not malfunction.
• If AWD warning lamp is flashing rapidly, stop vehicle and allow it to idle for some time. Flashing will stop and AWD system will be restored.
• When driving, AWD warning lamp may flash slowly if there is a significant difference in diameter of the tires. At this time, vehicle performance is not fully available and cautious driving is required. (Continues until engine is turned OFF.)
• If the warning lamp flashes slowly during driving but remains OFF after engine is restarted, the system is normal. If it again flashes slowly after driving for some time, vehicle must be inspected.
• When the difference of revolution speed between the front and rear wheel the shift occasionally changes to direct 4-wheel driving conditions automatically. This is not malfunction.
ZAll-Wheel Drive (AWD) models
CAUTION
Always use tires of the same type, size, brand, construction (bias, bias-belted or radial), and tread pattern on all four wheels. Failure to do so may result in a circumference difference between tires on the front and rear axles which will cause excessive tire wear and may damage the transmission, transfer case and differential gears.
ONLY use spare tires specified for the AWD model.
If excessive tire wear is found, it is recommended that all four tires be replaced with tires of the same size, brand, construction and treadpattern. The tire pressure and wheel alignment should also be checked and corrected as necessary. Contact an INFINITI dealer.
I would not think that would cause a problem.Phantom Infiniti wrote:I understand you cannot run a staggared wheel set up, but what if u just bought 4 of the same wheel. Say the 08 g37 coupe wheels. Just buy 4 front rims. Would that work (problem free) on an 06 m35x?
Thanks
Well i figured id go with the same width of 8.5 to avoid rubbing. But i dont even know if there will be rubbing. Will there? Hahamexillis wrote:"Phantom...If you can find just the fronts or just the rears why not get the rears and put on 255 since they are 9"s wide.
