Chris28 wrote:There are two different discussions going on. I'm 99.99% sure nobody has ever put a roller rocker SR into a RWD s chassis, it's not feasible. There is no kit for the swap.
The VE head on the DE block has been done, like stated Mazworks makes a kit. It's an involved swap, and it adds some low and mid-range torque and horsepower to the SR. Not worth the price tag. Google it if you're interested, there's an entire build thread on Fresh Alloy.
OP...it's your story, you can do whatever you want, but you have a lot of learning to do.
The biggest advantage to it is that the ve heads have shaft mounted rockers(goodbye floating rockers, hello 9000+ rpm), the vvl (Nissan v-tack yo) is an added bonus or annoyance depending on your point of view.
I've never heard of rr sr in a 240, but seeing as a ve head can be swapped onto a rwd block fairly easy, I would assume that putting the rr head on the rwd block would be a pretty straight forward and similar process the ve head swap.
