S13 and S14 FSTB
A forum for approved vendors of specialized, limited-production parts. Help small businesses that cater to Nissan enthusiasts and score some unique, useful parts! Contact [email protected] for approval and rates.
Jonnie Fraz
Well boys and girls I am building front strut tower braces for both the S13 and S14 chassis.
They are a solid design, with no joints to flex.All end plates and gussets are laser cut.
I do have an integrated brake master cylinder stopper avalible for an extra $20.00.
FSTB for both the S13 and S14 are only $120.00 with out the BMC stopperFSTB with the BMC stopper is $140.00.
Feel free to ask any questions either here or e-mail me [email protected].
Surfsup
Car: 1997 240SX rb25
Will these work on an s14 with an rb25?
Jonnie Fraz
Surfsup wrote:Will these work on an s14 with an rb25?
Honestly I have not tried an S14 with an RB. Here is a pic of the S14 bar with a KA.
Ajax
Car: 1991 240sx SE
2010 Mazda 5
wow that looks beefy. I'll have to think about this fitting into my winter budget.
mm_ibrahim412
Car: 1992 Nissan 240sx
will it fit an ls1 in my s13?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Do you take credit card payment?
Jonnie Fraz
sx moneypit wrote:Do you take credit card payment?
Through Paypal
sx moneypit
1986 Toyota MR2
Do you have these in stock or are they made by order?
bspeed_il
Car: s13 vert. rb25.
winter works in the process...
OMG. These look awesome! Do they fit the s13 w rb25? I don't have the stock intake so no worries for clearance...
Also, how long will you be offering these?Nice job on em
Jonnie Fraz
I ussually make them to order, but it does not take me long.
As for the RB depending on your mounts it should fit fine,especialy if you are running an aftermarket manifold. It does not fit the S14 SR20det in the S13 chassis, that is the one that I am trying to overcome right now.
sx moneypit
1986 Toyota MR2
What is the build time for the front strut brace and the tension rod brace? :
Jonnie Fraz
sx moneypit wrote:What is the build time for the front strut brace and the tension rod brace? :
I have them both right now.
float_6969
Jonnie Fraz wrote:I ussually make them to order, but it does not take me long.
Do you know if it will clear an S14 SR in an S14? I have a CA18DET in an S14 and the clearance should be similar.
You might try to do it like this. This style of STB is one of the few that will clear a CA18DET in an S13.
Jonnie Fraz
float_6969 wrote:Do you know if it will clear an S14 SR in an S14? I have a CA18DET in an S14 and the clearance should be similar.
Thanks for the input on the brace...unfortuneitly the tubing that I use is much bigger than the Nismo tubing, and there is just not enough room between the bar and the hood. I am working on a solution though.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Johnnie, totally dig the new brace. My 4pt. underbrace made it through a pretty substantial front in collision, didn't bend at all. Very well made, kept the front suspension in tact as well! If you ever have time, you should make a bolt-on (no strut bar needed) brake master cyl. brace for s14s. Wouldn't take that much, but nobody except Cusco makes one and they're hard to find, if you even can. Just an idea that would benefit you and the rest of the community
float_6969
And a rear STB for the S14. Most of the ones out there suck. I like the NISMO style ones that go above the rear decklid.
Jonnie Fraz
What happened? I hope you were not hurt.
I will look into the stand alone BMC stopper. I have some cool new parts in mind...just need the time to work on R&D.
slivic
I am interested in one for an s14 with sr redtop. I have a top feed fuel rail that causes some clearance issues with other bars, do you know if this will clear?
jrb92se
Car: 1989 Nissan S13 coupe
hey man im interested in one of these i have an 89 s13 with an rb25det with the stock intake mani. and a silvia conv. i have top hat mounts. do you think that this will fit or that you can make one that will? ... ive tried a few (cusco a circuit sport, and a few others including some no names my friends have) butt the hood doesnt close or the dont clean the intak mani . let me know if you can do it if you need any help or pictures etc tell me and ill send thanks alot bud>?
Dano
Jonnie Fraz wrote:What happened? I hope you were not hurt.
I wasn't hurt bad, an elderly couple didn't look before pulling out on a rural road, and I hit them at ~40mph, nothing I could've done to avoid it. They admitted guilt, but car was totalled and I bought it back. It really looks like your brace and the strut bar worked together to keep the whole suspension in tact and even better in place. The bulk of the impact took place literally 1/2" above the frame, so it appears to have remained untouched. Sooo lucky. I'm just now starting to work on fixing it.
I'm very excited to see what other products your going to come out with, i've already got a Cusco front strut bar, so i'm not in the market for that right now, but the standalone brake master cyl. brace I think would be a big hit. I'll be sending you an email in regards to that soon!
And back to the topic, guys, Johnnie's stuff is great quality, don't hesitate to pick up his stuff, AND... I HIGHLY ENCOURAGE you all to opt for the brake master cylinder brace upgrade, makes such a huge difference!
-Dan
float_6969
If I purchased this, and found that it wouldn't clear my chassis/motor combo, could I get a refund for the purchase price? (I'd pay shipping both ways) Either that, or could I get some measurements from the bottom of the hood to the top of the STB and the bottom of the STB over the intake manifold and turbo manifolds? (I have a top mount turbo as well).
jrb92se
i believe my first post was confusing i have a stock rb25det, with top hat engine mounts, not a top mount turbo, the turbo is in the stock position. and i have silvia hood, let me knoewif there is anything i can to to help the process.
Jonnie Fraz
jrb92se wrote:i believe my first post was confusing i have a stock rb25det, with top hat engine mounts, not a top mount turbo, the turbo is in the stock position. and i have silvia hood, let me knoewif there is anything i can to to help the process.
Please send me a couple of pics of your set up. I have built one for the CA, wich no offence was based on the RB. Truly Jason's bar (Rotoimp) may be a better bet if he has any. If not I am sure we can work it out.
Jonnie Fraz
slivic wrote:I am interested in one for an s14 with sr redtop. I have a top feed fuel rail that causes some clearance issues with other bars, do you know if this will clear?
Please send me a pic of your set up and I am sure I can tell you if it will work or not.
([email protected])
jrb92se
pictures sent let me know if they help
Modified by jrb92se at 1:36 PM 3/14/2010
Snowman864
how much with shipping for the s13
Jonnie Fraz
Sorry guys I have had some issues getting on the site. I have them worked out now.
how much with shipping for the s13?
To where? Send me your zip and I can work up a quote for you.
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
float_6969 wrote:And a rear STB for the S14. Most of the ones out there suck. I like the NISMO style ones that go above the rear decklid.
any word on RSTB for S14? I'd really like to buy them as a set
RsrS14
Car: 97 S14 240sx
interested!
Andrew28
Car: 92 hatch
How much shipped to canada postal code t6t1h6?
Return to “Fabricators' Market”
