Replacing your 350z a/c ventilator. (driver side)
Nissan 350z / Nissan 370z general community discussion forum
dasoupdude
Car: 2005 Nissan 350Z
Replacing your A/C ventilator:difficulty rating : .5 stars out of 10
1) pop off door panel
2)Locate the a/c tunnel which leads to the vent.
3)unscrew all screws, and simply just pull out
4)pop out old ventilator by using a flathead on the one of two metal holders to help squeeze and push through (try not to crack the plastic!)
5)Slide new vent in, and push everything back in place
6)Mount screws back and pop door panel on.
sit back and enjoy the sight of something you have accomplished which isn't even noticeable.
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
thank you sir....you forgot the pic of the finished product with the corny thumbs up
dasoupdude
lol k ill do it right now, i was in a rush
sardion56
Car: 2007 350z - Touring
out of curiosity - why replace?
dasoupdude
The support holding the louvers in place broke, so they couldn't all be fixed to the same direction. They were pretty much just flapping around everywhere and they could not stay open.
sardion56
thanks for the info! I haven't seen that happen in years.
dasoupdude
FAIL.
I dunno why I have kept it, i even still have my old cracked door handle.
as seen here.
zerothread/351786
Man, the first months of having the Z sucked lol
_b.jaye_
Car: '03 350Z
ill be damn. i thought mine was a fluke or the retard brain-child of the idiots that had the car before me. (exact same problem)
where you score the replacement soup?
no idea how i didnt see this when it was created
dasoupdude
I went to the Nissan dealership at the service/parts desk, I explained which part I needed, he flipped the monitor over to make sure that was the right part. (since I didn't know the part number or exact name. )
Usually the part won't be in stock because not many people order a/c vents for Z's lol
You can also check out courtesy parts, good oem stuff. Ebay sometimes works too.
http://www.courtesyparts.com/3....html
By looking at the assy picture you can tell which part and number it is that you need, erhm I can't seem to find the side vent though on the site. You just might have to drop in to your local Nissan or give Nissan of Texas a call.
_b.jaye_
Car: '03 350Z
nice, now i atleast know what to call the little mother. thanks man.
couple quick searches are none too promising either, so id say your right... dealership bound
dasoupdude
Ventilator, vent, driver side door a/c louvers, etc.
When you get it don't forget to post pics of your adventure. I kinda rushed this writeup.
Good luck, the air should feel a lot more direct once its in. And that equals happy driver
Return to “350z / 370z Discussion”
