Dznutts »
https://forums.nicoclub.com/dznutts-u135287.html
Sat Aug 29, 2009 11:58 pm
Van started acting up! It will start up and run for a couple of minutes. Then dies and doesn't start anymore, just cranks and cranks.
Someone said it was the sensor by the throttle body. So we changed that, added a new air filter, and I think they bought a new throttle body also for it. But it still does it. No Luck there.
I decided to check the fuses and low and behold, I found that the o2 sensor fuse under the dash is blown. Changed the fuse. So now it starts. I let it run for about ten minutes, then it starts to bog out and then dies. Started it back up, but I had to give it a little gas to get it started. It will start and run for a lil bit then it will bog out and stumble. Got to give it some gas when it tries to die. It will eventually bog out then die.
Do you think its a bad o2 sensor? Since the fuse was blown.Or I was thinking maybe the catylic converter is clogged up?
I don't know what it could be, I ran out of sunlight today. But I'm going to mess with it again tomorrow after church. I will let you guys know what else is going on with it.
Thanks in advamce for any advice any of you guys can give... . .
Modified by Dznutts at 3:05 AM 8/30/2009
Modified by Dznutts at 3:06 AM 8/30/2009
