Discuss topics related to the VQ series engine.
Nissan Infiniti Power Valve Assembly repair VQ35DE DIY Intak
Postby dprime » Mon May 14, 2012 6:32 pm
On the passenger side of this model engine, there is a small solenoid that powers a butterfly valve that varies the length of the air intake before the manifold. Nissan calls this the "power valve" The little plastic clip deteriorates over time and the push rod separates from the valve. Nissan wants over $100.00 for the valve assembly and does not sell the clip alone.... but I do. I have one of these engines and after listening to that valve rattle, and pushing the actuator rod through what was left of the plastic clip for the umpteenth time, I went looking for a repair option. This is it. This clip installs in seconds and restores functionality to the Power Valve.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290711111225&ssPageName=STRK:MESE:IT
dprime
Car: 2004 I-35
Re: Nissan Infiniti Power Valve Assembly repair VQ35DE DIY I
Postby jroo » Fri Mar 08, 2013 7:49 am
sent you a PM about this
jroo
Car: 2004 Nissan Pathfinder
Postby dprime » Fri Mar 08, 2013 8:57 am
I cant seem to reply to your PM so I will here.. If you look at the pictures on ebay, you will see the pushrod and where it goes through the plastic clip into the valve. If your plastic clip is intact... you dont have a problem. If your pushrod comes free from the valve, you need to replace it. Replacement is very easy... push the clip through the valve, put the pushrod through the clip... then rotate the clip until it locks itself back on the pushrod... very intuitive.
dprime
Car: 2004 I-35
Return to VQ30DE / VQ35DE / VQ35HR Forum
