ztommyx wrote:^^ i have done this otherwise i wouldn't know.
on stock studs, i don't recommend anything more than 3mm spacer (5mm is pushing it) otherwise you would need longer studs.
i will show you a 30mm on a 60mm stud and still be able to tighten the lug nuts tomorrow.
60mm - 30mm= 30mm (1.18 in.) thread left. enough to thread a nut
stay tuned.
Wait....you just said a 5mm spacer is pushing it on stock studs....i agree. Yet you are saying a 30mm spacer on 15 mm longer studs is doable??? You are completely contradicting yourself. THAT IS THE SAME AS PUTTING A 15MM SPACER ON STOCK STUDS, when just before you said 5mm is pushing it. You are adding 15mm length to the stud, but putting a 30mm spacer on top of it, so you just overshot your stud. You *might* get a few threads on it, but you are crazy if you drive on that, absolutely nuts.
FYI - 60mm is the total length of the stud from head to tip. Let's do some math.
60mm - 3mm for head of stud which is behind the hub - 9mm of actual hub width that the knurl of the stud sits in - width of brake rotor mounting surface (~8mm for the Stillen rotors in my garage) - 10mm for the typical thickness of the mounting hole on wheels (just measured my 5Zigen wheels, I would also measure my DP wheels but didnt feel like taking them off). All of these subtractions are widths of material that exist in between the hub and the lug nut (threads) and the 3mm worth of the head of the stud, which is on the other side of the hub.
Now all of these thicknesses I have just measured. So in summary:
60mm - 3mm - 9mm - 8mm - 10mm = 30mm
So, with a 60mm stud AND NO SPACER you have exactly 30mm of threads to bolt onto. I would certainly love to see you ad (or subtract rather) a 30mm spacer into the above equation.
60mm - 12mm lost upon installing studs - 8mm lost with brake rotor mounting plate - 10mm lost with thickness of wheel mounting plate - 30mm spacer = 0mm.......
I don't see what you will thread a lugnut onto, but it is quite nice how all those numbers worked out perfectly. HAH!
Logically, mathematically... nothing you have said makes sense. Not to mention you have contradicted yourself.
Even if you show me that you have done it, as it could be possible with a narrow brake rotor mounting plate and thin wheel mounting plates. I will still not think that is anywhere near safe as you would have to lose 10mm of thickness between the two parts, which would make the mounting plates pretty weak IMO. 5Zigen will only grind off 5mm of their wheels mounting plates. Any further and they wont do it for safety. If you don't beleive me, call them up. Their headquarters is in Compton, CA. I've been there several times to talk with them about different things. And if you do the math, based upon your previous statement about 5mm spacers being a stretch on stock studs, I think you will agree.
45mm - 3mm - 9mm - 8mm - 10mm = 15mm to thread onto. Add a 5mm spacer and you have 10mm of thread. So you are saying the least amount you would go is 10mm to bolt a wheel on. That is a wise decision in my mind. anything less is just too dangerous in my eyes.
