What hooks up better?
vikesfankevin86
Car: 95 Nissan 300ZX TT
What setting do you have you suspension on when you are at the track or go from a dig? I have less tire spin when it is on the softer setting. Even if I go from a roll my tire spin at about 4,000 rpms. It could just be the tires but they are bigger than stock. I have the stock ones on right now and I light those up.
car nut
Car: GT500.
Soft up front. You want the front of the car to lift and transfer as much weight possibly to the rear wheels. The problem with Z's is that they are very nose heavy and theres hardly any weight past the rear wheels.
The single best mod you can do for traction is a good set of tires. Get some nice fat street radials on a 17x9 wheel. You could fit a nice 285/50/17 BF Goodrich or M/T street radial on those.
As far as suspension stuff, try this;
http://www.powertrix.com/agora...nsion
Go down to where it says "Rear Competition Suspension KIT - Z32 TT - Powertrix". Buy that. Then buy the "Rear Differential Carrier Bushings", and the "Subframe Spacers - Specialty-Z". Go to an alignment shop and get your rear camber and toe set to 0. I'd also recommend a rear strut bar and stiffer sway bar to keep the rear wheels planted and eliminate flex in the rear.
Another thing you can do is relocate your battery to the trunk. This will shift a good 30 pounds from the front to the rear of the car. Put it in the passenger side corner of the trunk, under the tail light.
vikesfankevin86
That sounds expensive but it will need to be done in the future. I will ask my buddy if he can do the battery when he does the other stuff. I believe the tires on my after market rims are 9.5 inches. I was going to get some tires that were 10 because they would fit on those rims.
car nut
Car: GT500.
The battery is pretty easy to do, you can get a kit for like $50.
The most important thing with the tires is the type of tires they are. You want a wide, soft tire with soft sidewalls so the tire will absorb some of the stress from the power, instead of just putting it all to the ground.
You know what kind of tire you have?
vikesfankevin86
falken tires
car nut
Car: GT500.
Lol more specific. then that! Brand, model and sizes.
vikesfankevin86
ugh ok 1 sec i need to bring them inside. It is too dark in the garage.
vikesfankevin86
Ok I don't know what is what so I just wrote stuff down. Here are some of the things it saidZIEX ZE512steel belted radial265/35Z/R18 93WWhen I measure across they are 9.5 inches.
itZjoker
Car: 1996 2+0 5spd 300zx N/A
I read somewhere that stock suspension is best for drag racing but I dont know (really I dont)
vikesfankevin86
Well there is the touring and sport mode. They both come with the car.
car nut
Car: GT500.
itZjoker wrote:I read somewhere that stock suspension is best for drag racing but I dont know (really I dont)
For springs/struts I'd say yes but not for control arms, bushings, etc.
Do you still have your OEM TT rear wheels? If not, grab a set of those (you can find them on craigslist for about $100). Make sure they're the rears though (the rears are 8.5" wide, the front are 7.5"). Then buy a set of these P255/50R16. The tires you have are good for corners, but you'll just spin them all over the place from a dig. These will really help.
vikesfankevin86
Yea I actually have the OEM ones on right now. I wanted my rims on though so I would like to get tires for those. The tires now do spin like crazy. What should I get for my rims?
car nut
Car: GT500.
If your new wheels are 17x9.5, then get the 275/40R17's.
vikesfankevin86
ok thanks
