I still retain the foglights 3000k DDM. Anyway, I went ahead and bought an H11 Morimoto 3Five HID kit with XB35 bulb 5000k for the low beam.
I believe this is the best place to install the ballast.
The bolt and nut are provided in the HID kit. I removed the original bolt and use the provided one that tightly fits into the hole.
BTW, I did not use the provided relay harness since our stock harness gives enough juice to the ballast. (No flickers) My DDM HID that were replaced hooked up the same way and never had a problem. I had more problem using the DDM relay harness on my original installation 4 years ago.
