carlos_knology »
https://forums.nicoclub.com/carlos-knology-u278.html
Fri Feb 24, 2006 6:41 pm
Hey guys, long time since I've gotten on here. You CAN remove the lid without having to take everything apart... headliner, etc.
Here's what you do... Open sunroof about half-way. You want to open it just enough to fit your head in the opening. Kneel on the driver seat (facing rear of car) and look between the outer lid (the outer metal part) and the felt lined part. On the right and left sides, you'll see two black spring loaded plastic clips that you have to unhook. I used a couple putty-knives for this. The trick is to push the felt liner towards the back of the car as you pull up on the spring loaded clips.
Basically you're trying to separate the liner from the sunroof lid to expose the six bolts that attach the lid to the sunroof rail. Anyway, as the felt-lined half starts to slide back close the sunroof a little more, this will allow the felt piece to slide further. You'll need to keep doing this until the sunroof is completely closed and the felt liner half is basically slid all the way back. Don't worry, it can't slide too far back (there's a metal bracket in the back of the assembly that keeps the felt from going too far back).
Anyway, once the 6 bolts are exposed, you can easily remove the lid and replace the seal/weatherstipping. Put the lid back on and reattach the 6 bolts.
Once finished, open the lid all the way. Opening the lid all the way will make the metal lid slip back over the felt-lined half and you'll hear the spring-loaded clips re-engage. Close the sunroof and both halves will close like the always have.
Good luck.
