Called RAW last thursday they appologized for pistons not including rings like they said when I ordered over the phone.
No worries they shipped them no charge and they showed up today!
Verified part number and im in good shape.
MAJOR PROPS TO RAW FOR PULLING THOUGH FOR ME!!!
Dropped off everything at the machine shop today!
-Crankshaft only getting collar installed.
They talked me out of getting it hot tanked because they recommended drilling out the oil holes cleaning and plugging. Also they wanted to polish it verify my clearances and it would have just been another 2-300$. I decided just to install the collar and leave it alone since the engine didnt suffer any bearing damage and was in good running condition. I understand their theory that the hot tank will bake crud up in the oil galley then it come out later.....BAD
-Block will be hot tanked bored/honed .40 over all freeze plugs removed.
0025 piston to wall clearance is what we came up with. Supertech rec. .0023 they said since im gonna be running her hard a bit more is a good idea. I find it hard to imagine they have the ability to machine to within .0002 reguardless.......
Lastly I told them not to install any freeze plugs after block is hot tanked as I had bad luck with last machine shop on cleaning bores thoughly. Only reason they taking out coolant freeze plugs for hot tank is because they stated hot tank debris left over will kill water pump...... I argued this a bit but decided couldnt hurt and they could provide new plugs...19 coolant block plugs......guy was like HOLY CRAP thats alot of plugs. (very common problem for all machine shops) I also like to DIY the cleaing everything as its the...#1 I believe cause of engine failure.
-Cylinder head is getting hot tanked only.
Cylinder head was less than .0005 warp. Block is right at .0015 warp in one spot ill take my chances. I took the time to lap all valves before hand and verify all was in good shape. I also grabbed a fine 1inch wire wheel and cleaned up the combustion chambers quick. (extra careful didnt hit head surface!) Figured id throw it in the hot tank just to get all that carbon out of the exhuast ports.
-Rods will be getting arp hardware installed.
Me and the machinist were on different planets on this one. I stated I wanted my arp rod bolts intalled and rods line honed/bored to standard size. He advised I get crank gone through mic'd and polished if needed then rod big end size would be resized if needed. I stated that I thought the rod big ends would have to be resized with arp hardware. He stated if they distort which he seemed to believe they would not most likely. Long story short I talked to their crankshaft guy and he stated that when pressing in arp rod bolts the rods sometimes distort this is why they need to be "aligned". I told him that makes sense because id heard of people not getting "resized or aligned" after arp install and that I thought distortion was due to the increased torque. He stated that the distortion takes place when the rod bolts are pressed in.
Quoted me around 400$ and I walked out hopefully done in a week!
