Ka24dee Timing Help With Pics
lebgangstah
Car: 1992 240sx s13
yes yes iv searched around.. and alot that i have seen look un accurate and need to make sure i have it right i really dont wanna take apart the engine for the 3rd time so im gonna try and get it right this time.. i got a mechanic to set it up for me but he didnt bother useing the the marks he was close to them tho but... here are some pics maybe u guys can tell me if im right or off by a bit thanks!
S13_RB25
Car: A 240 but no RB yet!
That's how its supposed to be on TDC on compression stroke, looks good to me!
lebgangstah
Car: 1992 240sx s13
alright thanks man , also , whats the easiest way ?? to left my motor up need to get my oil pan out and clean it , also its pretty hard trying to put the oil pump back on.
S13_RB25
The easiest way is to hook the engine hoist up to the engine and lift high enough for you to get the oil pan out! Don't you have the the oil pickup tube out with the pump?? Cause in that case just take the bolts off of the oil pan and you should have enough room to drop and pull the pan out! Also to put it back on with the oil pump and pickup tube, do it this way:
1) Let the oil pan rest on the cross member, yes meaning don't bolt it back up, and have a layer of liquid gasket on the area of the pan where it will contact the block!
2) From an angel try to get the pickup tube into the pan, w/o damaging the screen or anything else, and bolt up the pump.
3) Put a layer of liquid gasket on the pan on the front, where it will contact the oil pump.
4) bolt up the pan and then everything else and there ya go!
lebgangstah
Car: 1992 240sx s13
yea i got the pick up tube out .. but i have a ton of s*** in the oil pan idk were the hell antifreez came from but its in the oil pan now. so i wanna clean it out and clean everything put it all back in so my car runs better.. yea well im gonna have to do all this tom i guess... and try to borrow a hoist ! and i just figured i got 2 sensors ! broken on my transmission aswell so putting my car high enough tom to doo all this thanks for the help man.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
You just did a head gasket...... Of coarse there is gonna be coolant in your oil. I never do a hg w/o doing a coolant flush and Oil change.
lebgangstah
Car: 1992 240sx s13
yea well oh well , im still working on it waiting for a mechanic to come double check the timing, how hard is it to undo those engine mounts? looks like a biatch!!! just got 3 new sensors for my transmission aswell prob why my reverse and cruise control ddint work.
lebgangstah
Car: 1992 240sx s13
i was looking at my other pics and it didnt look like i showed the pints to well and after looking at how other have theres iv seen a few like mine and a few that arent.
S13_RB25
Thats right! Dude download the FSM (factory service manual) for it! It answers all your questions and that is how the timing is in the FSM too!
lebgangstah
Car: 1992 240sx s13
FSM was used :D and downloaded thanks just double checking!!!! its going together tom. i dont wanna take everything back apart! thannks! for the help
