saeedakobiakov wrote:fine,if you think that spending $700 to $800 for new tire is better then $100 for alignment is better way to go, then go for it.
Sport pkgs. in most car companies usually comes with bigger wheels and sportier tires, so you can get better road feel and enhanced cornering ability.
p.s. Antzrus,what tires and what condition were your original tires?did you do alignment?what you got now for tires?i want to do some comparing.Thanks,Caug.
When I purchased my M35x it had approx 32K miles on the OEM Goodyear RSA's. They were wearing real well, a lot of tread left. However, I had read about the tramlining problems on this and other sites and so naturally I went immediately w/the new tires. Yes, as I've noted in a previous post above, it would have been wiser to do an alignment first-but I had read so much about the problem w/the RSA's that I figured why waste $100 US. I figured right.
I think a good question would be: Has anyone herein tried changing to ContiExtremeContacts and not cured the tramlining? And again as I've noted in a previous post above, the tire change is not an absolute fix, it could be the alignment and steering rack too. Just a wise choice for the fix might be:
"do an alignment. Thereafter if no cure, get a set of ultra high performance tires that others have noted cure the problem (i.e. ContiExtremeContacts).
And finally if no cure still, go for a new steering rack (a rare cure...).
Still no cure, call me, we'll arrange for some Prozac..."
