+10000jrd450r wrote:will this work with all the rb motors? specifically the 25? You know any way to get the speedo to work in s13 rb25? Also what year did your cluster come out of?
i think i read it somewhere, more of a quote of a quote... funny because its true?mattleegee wrote:dude S133P3R that is the funniest s*** i have heardthe "catch pan"
Yes, it should work for the 25. Also, to fix your speedo (Yours is reading half value right?) If youre using an RB20 trans install a DOHC KA speed sensor... if youre using the RB25 trans use the 300zx N/a speed sensor, all fixed. (For mine i had to take the collar out of the sensor's plug and swap it with the collar insert from the stock plug... and itll work dead on. used a GPS AND Radar to test my speedo. Oh, and use the search function man im tired of typing all this out haha (Dont use the crappy google search at the top right use the flashing Search banner at the top middle.)jrd450r wrote:will this work with all the rb motors? specifically the 25? You know any way to get the speedo to work in s13 rb25? Also what year did your cluster come out of?
what did u buy the j30 or the skyline cluster ?Nissan2367 wrote:I just bought one.. I hope it works like you said but hey it was only 30.00 shipped!
I can tell you, I did the same thing but its not accurate. Certainly not as accurate as using a J30 tach or anything like that.DeformityX wrote:Hell im still using my stock tach with my RB25 and its dead on =D Just turn the adjusting pot all the way clockwise then fine tune it. Idle is right at FSM specs and the rev limiter tachs right when it should. Win.
J30 Cluster. R33 cluster and rpm gauge need mods to fit. J30 does not!preston240sx wrote:
As long as its +/- 100 or so im fine with it. Not like im going to the track all the time or anything240z4u wrote:
Prob just bought a new odo... i had to for my old s13 and i started over it 0 miles...placham wrote:Those last 2 pics what ever they are Maxima or something, they dont look right.Ether stock with Black Box Tuning/Dakota Digital for stock look -> J30-> or dont do it at all.
less than 1000miles on S13 chassis interesting.
