IDAHOTUNERS: Big Bore Sr22 Twinscroll Gt30 Build
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
hey guys,
well my motor didnt hold up to the boost and high revs i was doing.
blown piston rings.
so here are my new plans
whats happening first.
pulling apart the block, doing a .5mm over bore. possible going to a 9:1 or a 8:1 compression. switching to a MAP setup using AEM EMS. Port and polish the head, and polish the inside of the intake manifold. maybe bore out the inlet fora bigger throttle body.get some top feed fuel injectors 850-1000 cc range, for my later setup
oil cooler, oversized oil pan, and oil filter relocation should up the oil amount to around 6 qts
electric fans are coming too.cahnging up some collant lines
once that is done i will run a stock turbo to break the motor in. and see how much power i can get out of it.
who want to bet i can get close to 300 at the wheels.? lol it will be interesting.
I get free dynotime, on our schools brand new mustange dyno.
and depending on how my tax return goes. i will be buying a gt35r or gt3076r. probably the 3076 is more likely.
pics are coming later.
oh and i have a fs add in the engines section. i need the stuff gone to buy my new parts. zerothread?id=402432
PICS:
less then 1,000 miles on the clutch
ALL the junk off.
can some one say front main seal leaking?
stuff coming off
DAMAGE every single pistion was missing this part on the exhuast side. some worse then others. OVERBORE REQUIRED
ORGANIZATION:zip lock bags are your friendalong with a shop cartif this came out of order i would kill some one
Modified by idahotuner at 9:10 PM 2/17/2009
S14toRPS13
Sucks to hear that. I'm glad my turbo decided to give before my motor did. I still need cams and a ecu reflash before I could even think about reaching the numbers you reached though. So did 400 whp start ever start to feel slow to you?
s13-t
Car: s13 pig nose w/blacktop sr20det
Saw your last build and have seen all the vids on youtube, amazing car bro. sry it went tits up
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
S14toRPS13 wrote:Sucks to hear that. I'm glad my turbo decided to give before my motor did. I still need cams and a ecu reflash before I could even think about reaching the numbers you reached though. So did 400 whp start ever start to feel slow to you?
lol i actually never ran 400 hp on the streets. and to tell you the truth 370 never got old. i actually never got to play with it as much as i wanted too. but 500-550 is the next goal.
s13-t wrote:Saw your last build and have seen all the vids on youtube, amazing car bro. sry it went tits up
thanks man. but this new set up will be sick.
s13-t
yea i bet, I notice that the valve cover isnt green anymore
mRodiek
Car: Stock Hatch
I loved your previous build and Im sure this one will be just as good if not better, good to see your not selling it and going Z06 either lol youll be able to stomp on em even more now Cant wait to see what you do. So your allowed to keep all your stuff at school til its done? What class is that?!
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
s13-t wrote:yea i bet, I notice that the valve cover isnt green anymore
yeah it hasnt been green fora long time.
DriftBoy07 wrote:I loved your previous build and Im sure this one will be just as good if not better, good to see your not selling it and going Z06 either lol youll be able to stomp on em even more now Cant wait to see what you do. So your allowed to keep all your stuff at school til its done? What class is that?!
lol the z06 will still come eventually.
yes our auto program is a nice small family type program. like with 30 kids majoring in it. and we all keep our tools and stuff in the shop. the shop is there for use firstly and then used as a business secondly.
mRodiek
Car: Stock Hatch
Where do I sign...?
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
bottom of the page
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
This will be good!
White Comet
Car: fc, s13 and mazda6, Sierra
nice, i'm looking forward to the craziness of this build. as for getting close to 300 on a stock turbo, you'll easy do that. my friend dynoed at 280 with stock turbo and internals and nothing more then fmic, turbo manifold boost controller and power fc
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
yeah. i am not sure if i will do a twin scroll set up. because for what i want a gt3582r A/r .63 will do the job. now if i could get this for about the same as a gt3076 r that was twin scroll i would jump all over it.
with main hp goals being 500-550 possibly 600 with methanol injection,
i can do a none ts set up using this turbo for 3000 dollars. ............. but that means getting 272 cams. but then maybe my 264s would give it some mean mid range with a nice level peak.
the twin scroll gt3076 is $300 more then that..... hmmm do i want crazy mid range or more response these are things i need to figure out so i can make everything focus on it.
i need to research what alcohol with do to my rings and seals too.
but we will be doing some sick stuff here.
how much of an over bore will kinda be a deciding factor.
2ndcar
Car: 1991 240SX White 1991 240SX Gray 1995 Civic
Didn't you have plans to do a LS1? what happened to that idea?
Logan76
Car: Junk
Go with the 35R, your head looks nice and clean.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
haha yeah. so i am going to be set back a little now. i am going to have to re sleeve comptely. but that means i can go with a huge over bore.
so i just have to finda shop locally to install and do machine work for me.
one that wont F it up.
Logan76
Car: Junk
How large of an overbore? look into places that do Honda motors you may have luck finding someone to sleeve it and do it correctly then.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
the shops here are giving me a really great recomendation fora local guy. my auto tech professor. says he is the best machinest he has seen.
so DARTON sleeves are going in with maybe a 4 mm over bore. hmmm will be interesting.
Logan76
Car: Junk
damn should prove to be a hell of a build, what turbo manifold are you going with?
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
full race for sure. probably get all my turbo stuff through them.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Can't wait to see the before and after pics! Just make sure to spam pictures of the build lol. GL
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
ok i finally figured it out.
going for some crazy midrange.
3500-7500
everything is going to be focusing on this spot in the power band.
gt3076 will be the turbo. with a twin scroll setup.
over bore will be decided on when i talk to the machine shop to decided waht they think the best size would be for that range.
seems like bigger would.
i will stick with stock compression. for reliablity reasons.
now just buy my old turbo.
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Glad you didn't go with the LS-1.
Stripes
Car: hatch, coupe
So you were running a stock bottom end with all the upgrades you had? I didn't follow all of your other build thread... too many pages for me hahaha. I'll def keep checking up on this one though. Hope everything goes good :D
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
boro drift wrote:Glad you didn't go with the LS-1.
twin turbo superchaged ls1 will come but it will be in my vette. lol years away.
Stripes wrote:So you were running a stock bottom end with all the upgrades you had? I didn't follow all of your other build thread... too many pages for me hahaha. I'll def keep checking up on this one though. Hope everything goes good :D
yep stock bottom end. that was one of the cool things about it. 56 pages is huge lol.
everything when smooth getting the mottor out and apart. nota single stripped bolt. now i just got to take off al lthe little banjo bolts and crap so i can get it cleaned good after machining.
i just need my turbo to sell so i can order my parts and pay for machining
S14toRPS13
Okay, so you got me curious now. How much boost were you pushing on this motor on a regular basis. I was under the assumption that you had were running a low of 14 psi and a high of 24 psi, but you just said in another thread that you were only pushing 10 psi and only turning up the boost once in a while.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
lol normally was 10 psi of the actuator. then first setting on the boost controller was 16 psi once it got set up. and 2nd stage was 20 but spiking to 24. i only rant the 20-24 o nthe dyno.
the rest of the time i normally ran 10 or 16.
the 14 was before i got the avc-r programmed correctly
callmeweezy724
Car: 1990 240sx w/s13 blacktop swap, 1986 e30 325e 4dr 5spd,1997 infiniti Q45
Stupid question..but how did you end up killing your piston rings?? i saw your previous build thread what happen? I just installed my blacktop to find i have bad piston rings too, im gettin oil shooting out the breather filter on the valve cover T and my idle is iffyy sometimes..
S14toRPS13
idahotuner wrote:lol normally was 10 psi of the actuator. then first setting on the boost controller was 16 psi once it got set up. and 2nd stage was 20 but spiking to 24. i only rant the 20-24 o nthe dyno.
Wow, that's crazy! On my old set up I was running a low of 14 psi and a high of about 19 to 20 psi. That was until my old turbo blew out. Once I put in the GT2871R I kept it at 14 psi, but then again, I didn't push on it very much since. You must've been doing some crazy driving around town.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
burnouts and hitting 8000 rpms several times over heats the motor.
boro drift
You should look into Total Seal gapless rings for your build. I have them in my 7M. The 2-3% leak down is no joke, I tested!
