Hydraulic oil
el bon bon
Car: 93-249sx conv
Anyone know what type of oil is used in the Hydraulic system on a 93 vert ?
Hijacker
Car: '92 240sx Convertible
'94 F-150
EDIT: 10w motor oil.
el bon bon
Car: 93-249sx conv
okay, I was confused because the fluid is clear and the manual says to use SAE 10W motor oil.
Hijacker
'94 F-150
i just checked my FSM, and it sure does say it uses 10w motor oil. And i was looking at my pump resevoir, and it's motor oil. I edited my original post to reflect that.
What gets me is that I SWORE i thought the FSM said ATF, and ATF would make sense since it's a hydrolic fluid. Regular motor oil just doesn't sound like it would work for a hydrolic system.
NISTECH
Wait till you go ask for it at a part store. They look at you like your an idiot..lol
Parts jockey: 10W ?? what the hell you using straight 10w in??
Me: your gas tank ,smart ***!
redsilviavert
tenkawa_akito wrote:i just checked my FSM, and it sure does say it uses 10w motor oil. And i was looking at my pump resevoir, and it's motor oil. I edited my original post to reflect that.
\ My 93 leaks out all the fluid from pump, is the pump supposed to run after I turn off key?
NISTECH
The pump shouldnt run after you let go of the convertable switch. Either your switch is shorting out or you pump is.
