How to install HID's through the wheel well. (DIY w/pics)
toronto07altima
Car: 2007 Nissan Altima 3.5 SE
I got the same kit as Generic as well on ebay and it is pure plug and play (no re-wiring necessary). It was so easy that I am going to buy another set and install them in my fogs.
bina12834
Car: 06 G35 coupe
this may sound like a total noob questions, but since these kits are only low-beam, what happens with the high-beam? Dont headlight bulbs usually have both high and low beams in the same bulb?
toronto07altima
High and low beams are controlled with different bulbs in the Altima. It makes the most sense to just change the low beams since the high beams are rarely used. Also in Canada, we have to deal with day-time running lights which uses the high beam bulb so it’s a pain to mess with that.
I would suggest that you start with the low beam and if you like it, do the fogs as well.
bina12834
Car: 06 G35 coupe
well i have the 2.5SL so i dont currently have fogs, but i plan on getting OEM's sometime soon, and then getting so HIDs for those as well.
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
well, i finally got my hids for my low beams and fog lights. I went with 6000k for low beams and 5000k for fog lights. I purchased 2 separate wiring harnesses with relays and fuses to isolate the oem wirings and get 12VDC power direct from the battery.
Alot of work (roughly 5 hour process included removing the front bumper ) , but have a piece of mind knowing that it won't burn any oem wirings
my 6000k xentec bulbs work great; however, my 5000k xlight bulbs aren't. one xlight bulb was putting out pure white while the other is like halogen color. Asked generic and the seller, both told me to get give it sometime for breaking in. I'll wait and see.
Modified by kuhan at 6:44 PM 3/24/2008
Modified by kuhan at 6:45 PM 3/24/2008
marbee
Car: nissan altima coupe
Hi, I'm new to the forum and was contemplating on installing HID on my altima coupe, I was wondering is there a big difference between 5000k and 6000k HIDs as far as light output will the light start dissipating where it's just blue where you can't tell the cutoff at all. I like the 5000k just fine, but I was thinking of adding a slight tint overlays on the headlights and still have the same light output on the road.
generic808
Car: '08 Infiniti G35 S
'10 Infiniti EX35
If you're planning to tint your housing, definitely go with the 5000K. Remember, the higher up the K rating you go, the lower output (lumens) light you get. Light output = 5000K > 6000K
gucio69
Car: 2008 Nissan Altima Coupe 2.5S 6MT
generic did you mean "light output= 5000K<4000K" as in light output for 5000K is less than 4000K?
generic808
'10 Infiniti EX35
gucio69 wrote:generic did you mean "light output= 5000K<4000K" as in light output for 5000K is less than 4000K?
My bad. I meant 5000K > 6000K not 4000K
Altima2007
Car: 2007 Nissan Altima 2.5S
Thx to this post
I was able to install HID on my own. On the driver side I took the tire off but on the passanger side.....I was too lazy to get the tire off but there still some space so I was able to finish with tire attach to it
striklybidnis
Car: 2008 Altima Coupe 3.5L SE
Very nice write up-my 5000k's came in last night and I just installed them using the above directions. I did not take the tires off, so it took me a bit longer but they are in and everything is buttoned up fine.
One thing-the CEL came on a little bit after install. I remember seeing somethign about this so I will search a bit more as to why and update this post when I find it. For now I just disconnected the neg terminal again to see if it was just a one-time thing.
Thanks Generic.
Update: so to stop the CEL from coming on, you must reset the auto window feature the FIRST time you start the car after disconnecting the battery. Haven't had an issue since. If you turnt he car off and start again, the CEL will trip.
Mine didn't have relays-it was plug and play-the new harness clipped right into the stock harness, no extra wires.
Modified by striklybidnis at 8:22 AM 8/4/2008
jharold
Car: 08 Nissan Altima Sedan 2.5 S
How important is it to have the relay harness? My kit came with one but it didnt come with any instructions. I dont want to have to rip my car apart again if its not a big deal.
jharold
ok, so i just put some HIDs on my 08 Altima sedan 2.5S, however when i was installing them i ran into a problem, The kit came with a relay but no instructions for the relay. So i tried to figure out how to do it with out them but that didnt work to well there is to many different wires coming out of it. So, how important is it to have a relay. Do i really need it? I would think that I do but I dont really want to take it apart again. If I do need it i guess ill buy the high beams too and do it all in one wack again. I tried to contact the company for a shematic or some instructions but of course they wont comply. XenonUS is the company. I love the lights but they dont include very good instructions.....I would appreciate some thoughts...
thanks Guys
Modified by jharold at 6:22 AM 7/23/2008
miket11
Car: 2008, nissan, altima
how much did this HIDs cost you?
jharold
a little over 200 dollars
Hiram
Car: 2008 nissan altima 2.5 S+
mine only $99.00 and works very good. easy installation too. haha i got my HID kit here
http://www.xenongate.com/index.php[/url] just want to help...
anyone know is there any regularation of HID light use? i installed 8000k bulbs today, will i fine? i am in Rhode Island by the way.
fame925
i went to XENONLINK.COM to buy the HID CONVERSION KITS for both low and high beams...and one of the sales reps there told me i need the the H1 KIT for low and the 9005 KIT for high...
is this right cuz i saw some other people sayin they got the H11?
jharold
no bro h9 and h11 is what you need
fame925
damn lol....i just got another email sayin its the h1 for low and 9005 for high...i have a 08 altima hybrid so maybe its different??
jharold
sorry bro, i didnt know that yours was a hybrid....then yes h1 and 9005 is correct, sorry bout the confusion.. i love my lights dude they are awesome. i dont have the relay on them b/c ther was no instructions on the relay and it there was two wires that i couldnt figure out where to hook em to so i left it off, idk maybe sumday theyl just stop working and if not i guess ill know if ya need it or not....
l8r
alticoupe3.5
Car: NISSAN ALTIMA COUPE
i got an 3.5cvt altima coupe and i want to install HIDs replacing the fog lights on the bottom. i have stock xenons in my headlights as well. should i just replace both sets of lights with HIDs? what would you suggest for the lights? also, do i install the fogs the same way i would if i installed lights in my head lights (just like the DIY)?
jharold
If i already had xenons then i wouldn't go through all the mess of changing them to an aftermarket HID, but thats just me, i pulled up to an altima 3.5 with stock xenon and i couldnt tell the difference from mine and theirs and about the foglights, yea i would put the HIDs on them, but i havent installed them on mine yet b/c it didnt come with fog lights and i just havnt took the time to wire some up, search ebay for good foglights they are good links there.
fyrcomm
Car: 2008 Altima Coupe 2.5S CVT
2014 BMW 435i M Sport
just installed xentec 6000Ks... didn't even touch the install guide.. just read this thread! thanks everyone who helped out with this how-to!
imdavit
Car: 08' Radiant Silver Altima Coupe 2.5s
where did u get your xentecs ? amazon? and for how much?
cuz i cant find em for cheap on ebay anymoree
phobs
you can get them on eBay. I got a good quality 3000k kit for fog lights or headlights if you're interested.
hellonaltima
Car: 2009 altima sedan 2.5 SL package RED BRICK
how can i connect my hids ? i have the kit ... i have the box with the bulb cable connected to it and an extra cable ... what is that 1 for ? it has a connector on the end look like the 1 cable for the light bulb on the car and end in 2 cables..... i dont know how to upload pics here or i would
thanks
william
ps: 09 altima 2.5sl and im not sure how to do it
hellonaltima
here is one side of the kit i have
jharold
This looks like the same set up as i had, and if yours is like mine the instructions suck!! Im not no expert on this so i may be wrong but i think that the other cable is for a relay... I couldnt really figure out on my kit the best way to hook up the relay for them so i just ran them without the relay. It works, it has worked for about four months now, no problems. Just hook up your power wire and your box and test it out and see if it works. that worked for me. I still dont have what looks to be the "extra wire" hooked up. I guess do this at your own risk. its a little bit of work to get in there to this stuff so try to figure out what you want to do before you get in there. If you plan on running the relay then you would prob want to take the front bumper off. if not then def go thru the wheel well.just my opinion and im no expert but it worked for me.
l8r
hellonaltima
Thank you ... im going to start working on the car some time today ..... im going to do it like you said i just wanted some1 to confirm what my thoughts were lol
jharold
your welcome, yea i know what you mean. it wont take you long i did it in about an hour and a half, but you will do it faster because i spent prob 30 min. trying to figure that relay out let me know how it turns out post some pix too
