AIRBAG LIGHT RESET/DIAGNOSTIC PROCEDURE
From User Mode to Diagnosis Mode:
Diagnosis mode activates only when a malfunction is detected, by turning the ingition switch as follows:
1. Turn ignition switch "ON".
2. After "AIR BAG" warning lamp lights for 7 seconds, turn ignition switch "OFF" within 1 second.
3. Wait more than 3 seconds.
4. Repeat steps 1 to 3 three times.
5. Turn ignition switch "ON".
SRS will enter Diagnosis mode, if no malfunction is detected.
From Diagnosis Mode to User Mode:
After a malfunction is repaired, turn ignition switch "OFF" for at least one second, then back "ON". Diagnosis mode is returned to User Mode.
If Switching Diagnosis mode to User mode is required while malfunction is being detected, turn ignition switch as follows:
2. After "AIR BAG" warning lamp lights for 7 seconds, turn ignition switch "OFF" within one second.
**HOW TO ERASE SELF-DIAGNOSIS RESULTS**
Without Consult-II:
After a malfunction is repaired, switch the ignition "OFF" for at least one second, and then back "ON". Diagnosis mode returns to the User mode. At that time, the self-diagnostic result is cleared.
SpecVcepS
01-28-2004, 09:46 PM
CHECK ENGINE LIGHT RESET/DIAGNOSTIC PROCEDURE
In car ECM Diagnostics/ECM Reset procedure:
1) Sit in the driver's seat.
2) Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)
3) Fully depress and release the accelerator pedal five times in less than five seconds.
4) Wait exactly seven seconds. Fully depress the accelerator pedal for ten seconds until the MIL light flashes.
5) Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.
Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.)
The next three digits follow in turn in the same fashion except with faster blinks (0.3 second) and a 1.0-second pause between digits.
The ECM code repeats itself until you turn the ignition key to the OFF position, at which point the ECM resets itself to standard get-in-and-drive-the-car mode.
You can look up the trouble codes in the ESM/FSM; there's a bunch of them. In the ESM, refer to page EC-639.
Additionally, if you get four blinks of ten (0000), the ECM is indicating no malfunction.
I hope this helps.
