With that said, i'm glad you figured out the problem with your motor. Best of luck with the rest of the swap and enjoy Zilvia
lol yea it had a quarter tank in it and I put a few gallons of fresh gas. Im pretty sire it was the timing. With the crank at TDC, the mating marks on the cams were almost at 6 o'clock. I worked on it til 3am last night, so hopefully I got it fixedTimTurboZ wrote:Hoffman5982 wrote:I just noticed, pin 23(starter signal) is labled as orange/blue, but its actually orange/black. Sorry, I was really tired.
Small, crappy update:
The car started once today, ran for 10 seconds, and died. Since then, it just turns over but doesn't actually crank.
I check for spark, re-gapped the spark plugs to .44, checked fuel injectors and fuel lines, adjusted TPS from .97 volts back to .45, and checked all the grounds. Everything looked fine, but it still won't crank. I can let it sit for 30 seconds to a minute, and turn the key and it'll try to start but die instantly. I'm at a loss as to what is the cause. I pulled the harness out, went over all of it to make sure there wasn't anything wrong, and it was fine.
Anyone have any suggestions?
Just a thought...does your car have gas in the tank?
I had it temporarily ghetto rigged with some crappy wire. I have the 12g wire now and haven't had any more problems. It connects to the back of the alternator on a little bolt. Ill take a pic tomorrow for you. Could a grounding issue cause this? Should I add a few extra grounds just for safe measure?mrgreeneyes wrote:back on page 2 you mention an alternator "ground" wire. the alt grounds through the bracket/engine and sometimes has an OEM 12g wire going to the strut tower.
post pics of this. it has me wondering how you managed to catch it on fire.
and the hell with taking it to a shop. they will bend you OVER for that... and they will have NO info, cus we never were supposed to have that motor anyways...
