UPDATE!!!
I finally got to crank my car for the first time yesterday. The first couple of startups were pretty rough, but after a few minutes running it smoothed out a little. It idled at about 1k, which I know is pretty high, and the temps astayed right where they needed to be when it warmed up. On the first couple of startups, it would rev from 1k-2.5k, and drap down to about 700 rpms over and over by itself, and if I gave it a little bit of gas it would try to die. After it warmed up, It stopped doing it, and I could get it to about 2.5k rpms and then it would drop. And the engine shakes quite a bit. I have the engine bolted in, but not completely torqued down to spec. Would that cause this?
I then unplugged the ecu and everything and went to work. When i got home a friend came over to see it, so I hooked everything back up and tried to crank it, but all I got was the alternator clicking, and then I noticed some smoke. I got out to see what was causing it, and the wire I was using to temporarily ground the alternator literally melted. I replaced it, and got the same clicking result but no melting wire. We jumped the battery off, and the car would turn over but not crank.
I'm extremely happy. She started up perfectly after it had run all the crud out of the system. I still have to extend a few of the plugs on the harness and put everything back together. Hopefully I can get most of the stuff out of the way tomorrow.
I ended up making my own wiring diagram for the dash plug. So far, everything works great. the temp and rpm gauge read just fine. I didn't the speed sensor or anything like that plugged in so we'll see about that. I used these 2 diagrams with no luck. I couldn't even get power to the ecu:
http://zilvia.net/f/tech-talk/209158-ho ... assis.html (wiring at the bottom of first post)
http://i68.photobucket.com/albums/i40/h ... 006wu0.png
I'm not calling these guys out or anything, but neither of them worked for me.
Here is the one I made. Maybe it can help people with this swap, or atleast proved them with a template.
As you can see, pins 1,2,9,&10 are for cruise control. Just thought I'd point that out.
And here is the video of the car running. Unfortunately the video file for the first start is messed up, so Im going to see if I can make it play right. The car has no exhaust, which is why it sounds the way it does
[youtube]
http://www.youtube.com/watch?v=F3dnVuUrDSU[/youtube]
