help to get my car running right, LOTS of smoke at idle ect
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Right. It should at least provide spark to all 6 cylinders even if the fueling and MAF settings might be out of whack.
ANVIL
Car: RB25DET S13.5
Stumped bump
Anyone have any more ideas on what to check?
240z4u
Car: '95 Nissan 240SX
ANVIL wrote:I'm gonna try the stock ecu today but I don't know how it will run with the mods I have but if it actually is the ecu causing the problem then at the least it shouldn't misfire....right?
Are there different ecu for s1 and s2 power fc?
Should still start, but run SUPER rich.
The ecu is the same for S1/S2
Cliffsnotes; You aren't getting spark on cyl 3 right?
ANVIL
Car: RB25DET S13.5
Runs with the same misfire on the stock ecu. I'm going to double check spark to all cylinders and try my spare CAS sometime in the next few days.
d356bud
Car: 1990 240sx w/ RB25DET
did u check the ground wire on that cyl?
ANVIL
Car: RB25DET S13.5
Ground wire is good.
I'm kinda sceptical because cyl compresion is about 155ish but a friend of mine really thinks i have a bent valve in cyl 6... ? What do u guys think?
ANVIL
Car: RB25DET S13.5
everyone give up on trying help me figure this thing out?
say I DO have a bent valve in cyl 6, and it doesnt fire, but there is compressions, spark and fuel.... would it make sense that when i unplug coil for #1 cyl that the motor runs smoother?
