and that's just the start, most guys don't like to talk about when the system breaks.infiniti_lineup wrote:I was hoping that wasn't going to be the case, but you're right. Unfortunately, I just don't have that money to spend on the car right now.06M4.5 wrote:I think you need to jump to the VIP style which will need air suspension and maybe body work to get what you want. This means big bucks $$$$.
Did you know that the air suspension kit for the M45 runs $4,293 + $300 shipping + $1000 installation = $5,593 total.![]()
Ridiculously overpriced considering how much it really costs them to produce it. Maybe sometime in the future, though.
Here is the write up on it, the M has the same type of spring mount in the rear so I assume this could be done on the M.infiniti_lineup wrote:Hmm I need to look into that. I want to go as low as possible on springs and I don't care if I destroy the ride feel in the process.ctsedan wrote:FYI, I havent tried this yet, but on G35 some guys cut the rubber spring mounts to get .25"-.5" more drop in the rear. I have Eibach springs too and I dont like the front being so much lower than the rear.
As long as I'm low, I'm happy.
What's the distance between your tires and the fender in the rear on the Eibachs? Is there a VERY visible gap? Does it look bad?
these might be the one's you'll need since you have an X.bbs350z wrote:what sits lower for an m35x, s techs or eibachs?
infiniti_lineup wrote:Ahh that looks great! I think I'm going to order Tein S-Tech now instead of the end of November, and I just found out that they're a bit less expensive than Eibachs so that's another plus.
Thanks again man
