I tried to get a couple of used less than 100k vac pumps from chevys they were all rusted to death inside. New ones are not real cheap IIRC close to 2 bills.
Anywho you should see the nasty s*** pulled into my catch can(ran proper) Now ever after 6k with it not even a cup of fluid. Same car with same 6k had a can also install between vc and preturbo this can had nothing in it what so ever and was deleted.
FACT a real crank evac setup does better than vta or oem.' real meaning catch can and check valves , with a filter element inside the can'
FACT a setup with a pcv will have better oil longer.
FACT a setup with the lower timing cover blocked off and pulling atmosphere(better have a filter on that vc lol) is no longer a system with pcv.
gurus chime in on this;
300whp kat how much power is lost with a proper pcv vs vta?
Unless it is a 10% or more gain I see no reason to go vta other than aesthetics.
