J240sx »
https://forums.nicoclub.com/j240sx-u40731.html
Mon Apr 16, 2012 5:05 am
Recently finished a rebuild on my sr and on start up there is a strong gas smell, and white smoke from the exhaust. I changed my oil yesterday and there was a lot of gas in it. I am going to check my injectors today to see if they are leaking, if not I am going to assume its a problem with my piston rings. Is there any other things I should be looking at to see if that is the cause of the problem? Perhaps the maf, 02 sensor, or coolant temp sensor? The screw on my ecu is damaged so I am unable to pull codes, I am going to look for a new one.
Rebuild consisted of new pistons, rods, and bearings. Everything else is stock, besides Fmic and exhaust. Any advice would be greatly appreciated.
