ga1.6 swap to sr20de or ve???
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
S14Juggalo
Car: 95 240sx (S14)
How hard is it to swap a ga16 to an sr20 de or ve since their the same block? And what all does that entail? Its going in a 97 200sx se 5spd!
Oh and will the transmission bolt right up to the sr from the ga?
nametakennow
Car: '06 MINI Cooper S
Not much harder, just need different engine management.
Check out the FAQ about the 1.6->2.0 swap. There's a link in the Table of Contents linked-to in my sig.
S14Juggalo
Car: 95 240sx (S14)
Well I have read all the swap info i could and im still confused some people say that i need a bunch of parts from a se-r to hold the sr20 and others say i just need the se-r cross member or lower brace or something along those lines what EXACTLY do i need other then the obvious like motor, trans, clutch cable and and ecu?
nametakennow
nametakennow wrote:Check out the FAQ about the 1.6->2.0 swap. There's a link in the Table of Contents linked-to in my sig.
Here's a direct link to the FAQ:zerothread/133008
S14Juggalo
Car: 95 240sx (S14)
Ok kool thats the thread i was going to base my swap on thank you very much sir! Now my next question is off topic but do you know where i can find oem 5 spoke 200sx ser rims? The classifieds is cluttered with mainly 240 stuff for sale and will take me forever to find a set and most likely the add will be old and rims sold!
nametakennow
Try Craigslist or Ebay.
S14Juggalo
Car: 95 240sx (S14)
nope nothing
fjartjdm
need some help with my project. swaping a SR20VE-T
poweredbyNismo
Car: 1996 Nissan 200sx (project)
SR20VE=pwnage :)
codyace
Car: S14 w/redtop
I'm about 95% sure that when swapping a 2.0 into a non 2.0 chassis, you will need (essentially) everything from the front end...crossmemeber, transmission, axles, hubs etc etc etc.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
