G50 Exhaust replacement options.
rogue240sx
Car: '92 240sx hatch, '90 Q45, '10 WRX sport wagon, '73 Ford Gran Torino Sport
So the Exhaust in my '90 Q45 is leaking from several areas due to rust and i'm looking for some replacement ideas that are preferably bolt on and not full custom setups. So far my searches haven't turned up anything promising. Anyone out there have any ideas, or am I stuck having to have a new system made?
SanCarlosQ45
Car: 1994 Q45 144,000
2013 Nissan Xterra Pro-4x
1967 MGB GT Special
There are no bolt on exhaust kits for the G50, at least here in the states. This is much like everything else with this car, most if not all performance modifications have to be custom or from the Z32. Where has it rusted out? Are you looking to stay at around the same noise level or are you fine with something louder?
i-would-like-some-performance-exhaust-i ... 78154.html
rogue240sx
A little louder is fine, this isn't a daily driver. It's mostly a tinkering car that get's thrown around a track sideways occasionally. But I needs it to be street legal. As far as where it's rusted it'd be easier to say where isn't it rusted.
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Look for some in the junkyards. You should be able to find one with a good exhaust system. Drop the whole thing and bolt it back up on yours.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Depending on where you live, finding a good exhaust system is probably going to be tough.
If the pipes near the cats are good, then you can have an exhaust shop patch your exhaust system back up. I'd think for $200-$400 you should be able to get your exhaust system pretty much leak free.
rogue240sx
elwesso wrote:Depending on where you live, finding a good exhaust system is probably going to be tough.
I live in New England, so yeah, finding a complete exhaust that isn't rusted up is going to be a challenge.
Brew Q
Car: '92 Q45 91k miles, '05 FX35
past: '99 740i (r.i.p.), '92 Maxima SE, '89 Maxima SE, '04 FX35
Cut out the suitcase muffler while you're at it and put in either turn downs or tips. ;)
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Any exhaust from the junkyard will likely be hard restore. Most junkyards use acetylene torches to cut the metal. And of course the main cats and pre cats on the manifolds will be missing.
