So far on our 2008 no such problem, hopefully they had time to correct this on later production units.blacksmaru wrote:well if you try and start your car from a cold start, it`ll turn over, but wont crank for about 3-5 secs.... or if you dont hold it that long, it`ll crank the 2nd time you try to start... its been happening to alot of forum users after about 400 or so miles...
Thanks! I will try it out.boxcarbill wrote:there are 2 rubber bumpers that screw in and out. I already fine tuned mine to get the space between the hood and grille even all the way across.
He's got it right. They are only required to issue a recall if it is a safety issue. Otherwise they put out what is called a Technical Service Bulletin which is the comany admitng the part was defective from the factory. If you go in they have to replace it for free. The NHTSA has a databse of these listed here. http://www-odi.nhtsa.dot.gov/c...h.cfm07Vsdn wrote:this sounds more like a technical service bulletin (TSB) then a recall.
it is an important distinction because recalls are safety related issues and they are something you will get a mailing about versus a TSB which is an internal memo sent only to the dealer (they won't call you) informing them of the problem and how to fix it but only IF it is customer reported.
True! but if you ever run to lean for an extended period of time you can put a hole through a piston or two.BBISHOPPCM wrote:No, low fuel pressure should not increase fuel consumption.
this is funny, im almost in the same boat.The body shop rented me out a sentra.I had my car 3 weeks before the gods through down their wrath upon me.i hope i can start playing with my versa once again in less then a week.shakoz wrote:me too!! my versa has been in the shop 21 of the 45 days i have owned it and i have been driving a sentra.what a little pig car! the worst part is that the only key entry is on the driver's door so if you want to get in the passenger side you have to unlock the driver's side and push the unlock button on the armrest.
