qpe »
https://forums.nicoclub.com/qpe-u221035.html
Fri Jun 07, 2013 5:46 am
Hi I am only new to this site and Datsuns but I would start by checking that you have adequate earth and power supply to the fuse plate , have you painted the area recently? Try tracking back then looking for the same is supply arriving and leaving the voltage regulator is the earth sufficient have you disturbed anything in this area? You say you swapped out all the fuses..why/ it is unusual for them to all blow at once have you checked them out. If they did all blow there is possibly a short somewhere or the regulator is stuffed. Is your ignition switch loose? Check your manual for a diagram indicating the number of wires leaving the back of your ignition switch( believe it is 3) are they all tight and undamaged. Hope this of some help
Regards
QPE
