A lot of people say they have their box suffering from water damage.
It is a green box or orange box near the tail of the car that alerts you when you have a brake, but on the other hand if it goes out so do your tail lights.
Well here is a DIY project to bypass the useless sensor.
What you need:
-soldering gun
-solder
-wire(single,not bush)
-the old tail light sensor
What you do is unhook the tail light sensor (mines green, your may be orange as well). On the end with the plug there is a black part inside the green box pop that out and there should be a circuit board attached. What you are going to want to do is un-attach
the plug that plugged into the car from the circuit board so you have a free standing plug and circuit board. NOTE! Make sure you don't damage the plug when removing it just stick the solder gun to the ends and pop it loose.
Numbering of plugs:
4---3---2---1
5---6---7---8
!!!THE NUMBERS ARE ON THE CIRCUIT BOARD SO DON'T FORGET HOW IT GOES!!!
On the picture above is the jumper setup I did for the plug:
I soldered 4 to 5. (Tail lights)
I then soldered 2 to 7 and 8. (Brake lights)
Now plug it back into where the sensor goes and test your work.
to finish up put it back in the green box and electrical tape it up.
***I am not responsible for any damage you do this is just a guide I followed and it worked perfectly
