Difference between 8 port & 4 port engine??
rossmac
Is there any differenced between the 4 & 8 port engines ? are all parts, eg pistons, cylinder head, cams etc interchangerble?Cheers
float_6969
Cylinder head and lower manifold are the main differences. The block also has different threads for the head bolts. Other than that, they are identical.
4 port head - 4 intake ports, one for each cylinder, matching lower manifold, smaller threads in block for head. 8 port head - 8 intake ports, one for each intake valve, matching lower manifold, larger threads in block for head.
meminto
Car: S13 Silvia CA18DECT
Each head has its own unique fuel injector arrangement..
Ie: 8 port has the injector port located on left inlet runner on the sub plenum. 4 port is centered on the plenum..
So you need the correct plenums/rails/gaskets for each application..
Most other bits n pieces are interchangeable as far as I am aware, on a DET motor that is..
Edit: - What float said...
rossmac
Thanks for that dude,So to convert an 8 port to a 4 port you need the head, lower intake manifold part & the main head studs?
Could you tell me what the difference is between the studs? Are we talking about the head studs?Are they different thread or just longer/shorter?
Thanks
meminto
They are a different thread...
Talking about headstuds...
rossmac
Is there any way i could get around this other than drilling & tapping all the holes in the block?
meminto
It wont worry the head itself as the diameter of the stud holes shouldn't be dissimilar..
rossmac
Oh thats okay then,Do you think it would be okay to re-use the head studs and cometic head gasket?Reason is I have a clamped up 8 port head & i wanted to remove that & install my 4 port head.
Hopefully it will ba okay to re-use the parts as the engine hasn't even been run yet,
float_6969
The holes in the head are fine. It's the threads in the block that are different. Just get bolts/headstuds that match the block and you'll be fine. ARP makes headstuds for both the UK Spec and JDM/USDM Spec CA18DET's.
rossmac
I already have arp head bolts for the euro block Swap anyone ?
float_6969
What? If you have a euro block, and euro headstuds, you can use either head w/o a problem.
rossmac
JDM engine & block,Euro Head & ARP Studs
rossmac
Is it possible to re-use standard head bold and a cometic head gasket?the engine hasn't even been run yet
float_6969
Yes. I've never found anything in the FSM that states that the head bolts are TTY and would need replaced after removal.
MAKE VERY SURE that the head and block have BOTH been re-surfaced. And make sure they know you're using a metal HG. Cometics have a tendancy not to seal if the shop doesn't mill the block and head to the proper surface smoothness.
rossmac
Would the block need re,re-surfacing if its already been suitable for a mhg?Thanks for your help gents
float_6969
I would. There have been a lot of problems with people getting those headgaskets to seal. IDK if it's a motor thing, or a gasket thing. Cometic swears it's because the surfaces aren't being finished to the corrects roughness.
Valvebounce
Car: Datsun 1200, Datsun 510, NIssan WGC34 Stagea, Datsun Sunny PB310
Ross_Mac wrote:Thanks for that dude,So to convert an 8 port to a 4 port you need the head, lower intake manifold part & the main head studs?
Make sure you get the fuel rail too.
rossmac
float_6969 wrote:I would. There have been a lot of problems with people getting those headgaskets to seal. IDK if it's a motor thing, or a gasket thing. Cometic swears it's because the surfaces aren't being finished to the corrects roughness.
Really?The engine hasn't even been run since the block was surfaced & the head bolted on.Is there a way to check if the block if in tolerance/ finished good enough for a cometic hg?
rossmac
Help :D
meminto
If the block/head has been prepared to the specified roughness, I don't see there being an issue..
If it hasn't, then you either need to do it or use an oem gasket..
Without the finishing process, it will fail prematurely..
float_6969
From the Cometic website:"What surface finish is required to us an MLS head gasket?A surface finish of 50 RA (roughness average) or finer, is recommended for a proper gasket seal. Anything rougher may conflict with the gasket design."Talk to your engine builder and ask him what the RA of the head and and block were. Don't tell him it has to be 50 or finer and see what he says. If he didn't do it right, the cometic WILL leak.
Sideways s12
Car: 84 turbo s12
How can you tell if you have the 8 port or 4 port?
meminto
Without taking anything apart?
Easy visual sign is centered injector bosses on the sub manifold..
float_6969
There aren't any 4 port CA18's in the US unless somebody bought a CA18DET motor-set from japan, and then bought a 4 port head from Europe and slapped it on there, and then sold the car.
910bluebird
ive got one these head laying around somewhere , pretty much the same bar the injectors being centered like others have siad
ska69
Car: 200sx s13 ca18det
is there any way to tell which version (4port or 8port) is installed? I have a euro-spec '89 ca18det and up until today I had no clue about the 4port and 8port differences...
ferracing
Car: honda crx ed9 and nissan S13
Here you can view the version 8port
Modified by ferracing at 1:30 PM 3/14/2010
ska69
thanks! but forgive my stupidity, and how does a 4 port look like?
ska69
I think I found it
ska69
and this one here: zer...age=1
