dickhamlet »
https://forums.nicoclub.com/dickhamlet-u189563.html
Mon Aug 22, 2011 1:54 pm
I've just swapped an instrument cluster into a 1987 Nissan D21 extended
cab pickup. The new cluster from a junkyard has a tach and a clock; don't
know its year or model, but it's an exact fit for the old one that had
no tach. All the cable plugs were there, they fit and everything except
the tach worked immediately. The 4-prong plug into the tach (three live prongs)
has +12V, ground, and signal. On my truck the signal wire is white with
red splotchs, but colors may vary by year. I could not trace where this
wire goes and it seemed to be dead, so I started to search for a signal.
Several websites suggested various tach signal sources, but the only one
that would drive a 12V test light was off the transistor connected to
one of the coils. (Forgot to say that my truck has a Z24i engine, with
two coils and 8 plugs for four cylinders.) One site says this worked,
but I was a bit leery of it--there evidently was a tach connection
somewhere else. A local shop got me a wiring diagram for a 1995 truck,
which indicated that the tach is driven off the ECU computer. It also
showed several places where there were variations between the tach- and
non-tach wiring. Apparently the reason why the tach wasn't working is
that I had these variations, but I could not locate them in the actual
witing.
The ECU is located under the passenger seat. I tested lots of pins
on the ECU, but nothing detectable with a test light or a multimeter.
The wiring diagram showed tach signal on pin #3 of the left connector
(looking in from the passenger door). The pin numbers on the connectors
are stamped into the plastic, sometimes only "1" at one end if there isn't
space to stamp. No detectable signal on pin #3, (wire white with red splotches,
but not connected to the same-color tach wire) except that putting the
test light there made the engine stutter slightly. I guessed that one of
those alternate connections in the non-tach harness was breaking the path,
so I ran a wire direct from ECU pin 3 to the tach-signal connector on
the cluster, which worked perfectly. The circuit is evidently very high
impedance, low voltage, which is why it doesn't show on crude testers.
I ran it through a 100Kohm resistor at first, but then the tach didn't
work, so I made a direct connection. (The wiring diagram doesn't show
a resistor, but the Haynes manual did.)
Since the wiring diagram I had is for 1995, this tach signal should
probably work for a wide range of years. But it would take an
oscilliscope to see just what the signal is. It might not drive
after-market tachs because of the high impedance.
