How much CVT fluid to use?
Postby jadue123 » Thu Apr 19, 2012 9:00 am
how much oil is needed for cvt transmission?
with filter and without filter
jadue123
Car: 2011 rogue
Re: How much CVT fluid to use?
Postby ImStricken » Thu Apr 19, 2012 9:39 am
the CVT transmission requires approx:
7.5l (7.9qt) for FWD
8.6l (9.1qt) for AWD models.
- NS-2 fluid part no. 999MP-NS200P. Approx $15/qt.
- CVT drain pan plug gasket #11026-01M02
here are the instructions:
http://www.nicoclub.com/FSM/Rogue/2008/MA.pdf
Rogue DIY's & FAQ's - Nissan Rogue Field Service Manual - All Nissan TSB's
-=Subscribe To My YouTube Channel For DIY's!=-
AZhitman wrote:While IMstricken might be a butthole, he's OUR butthole, and you walked face-first into him (stink and all).
ImStricken
Car: _____________________
'13 Hyundai Santa Fe AWD
'08 Nissan Rogue SL
'07 Suzuki GSXR600
'06 Yamaha R6
'06 Carry-On Trailer
Postby jadue123 » Thu Apr 19, 2012 11:51 am
thank you
jadue123
Car: 2011 rogue
Postby kerrton » Thu Apr 19, 2012 12:55 pm
The CVT fluid lasts a very long time, I'm curious why you are considering changing the fluid, what is your mileage? Typically you can get well over 100,000 miles out of this fluid, and considering how expensive it is that is a good thing!
I know it goes without saying but it's so important that I'll repeat it once again for anyone in the future considering tackling this project - You MUST use the Nissan NS-2 CVT fluid, there are NO aftermarket options and any other fluid will destroy your CVT tranny in short order. The CVT fluid is completely different than normal automatic transmission fluid. Any shop that tells you they can change the fluid for you is probably not aware of this unless they plan to drive over to Nissan and purchase the fluid from them. If you are having a shop perform this maintenance, this is one instance where I'd say take it to your Nissan service shop - they are also the only ones who can test your fluid and let you know if it even needs to be changed!
kerrton
Car: 2008 Nissan Rogue, SL FWD, Gotham Gray
Postby jadue123 » Thu Apr 19, 2012 1:27 pm
it is 2011 rogue awd it has rebuilt title, and only 5000km.
i checked the fluid and was low so added 1 liter, i guess it was front ended.
it looks like they put new transmission cooler, i don't know if they added any fluid.
i just wanted to make sure if they added any fluid it was ns-2, anyway of checking?
jadue123
Car: 2011 rogue
Postby ImStricken » Fri Apr 20, 2012 6:10 am
i just wanted to make sure they added ns-2 fluid, anyway of checking?
unfortunately there is NO way of checking what fluid they used, unless you send the fluid out to be tested. my best advice would be to go to a nissan dealer, or any mechanic that can perform a FLUSH (not just a drain) on the transmission.
if you dont want to go that route, than you can just drain whats in there, and refill it with the right nissan CVT fluid and hope for the best.
kerrton wrote:If you are having a shop perform this maintenance, this is one instance where I'd say take it to your Nissan service shop
as much as i try to stay away from stealerships, i couldn't agree with you more. its gonna be on record that you had it changed at the right facility, under all the right conditions with the right fluid, and it cant be disputed that your mechanic used the wrong fluid, or did the job wrong. If a certified Nissan tech did the work, there is no arguments if you have a claim later down the road.
Furthermore, mechanics buy fluids, parts, and supplies at a certain price from the dealer, or distributor - and then add cost on top of that. So you might be able to actually get the work done cheaper at the supplier of this fluid, and thats a nissan dealer.
If a bottle of this fluid costs $10-$15 at the dealer, expect to pay $20-$25 at your private shop for this same fluid.
ImStricken
'08 Nissan Rogue SL
'07 Suzuki GSXR600
'06 Yamaha R6
Postby Rogue One » Fri Apr 20, 2012 7:35 am
Genuine NS-2 Fluid available from PerformanceNissanParts.Com
http://www.mynismo.com/products/?id=3914
NISSAN Continuously Variable Transmission (CVT) Fluid. Use where NISSAN CVT NS-2 Fluids are required in NISSAN, INFINITI, and other make vehicles. Check your owner's manual for manufacturer's service recommendations.
SHIPS UPS GROUND ONLY. IF ANY OTHER METHOD IS CHOSEN, ORDER WILL BE CANCELLED.
Part #: 999MP-NS200P Type: NS-2 Price: $14.95
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
"If looks could really kill, my occupation would be staring."
Rogue One
Car: '12 Black Amethyst Rogue SV w/ SL FWD
Postby Bill Lewis » Mon Jun 04, 2012 2:22 pm
I have a 2008 with 52k on it. Have a hitch and have doen some light towing of a small landscape trailer with my motorcycle and some household items. Just to clarify. Having just moved to Cape May NJ the nearest Nissan dealer is 40 miles away. There is a shop her recommended by a few friends. They say they can get the fluid from the Nissan dealer and drain and refill the CVT but don't have the equipment to do a flush. Is this OK or not. I don't understand the advantage of flushing the CVT if your changing the fluid. a little old fluid left in there can't hurt that much can it??
Sorry for my ignorance but I just want to take care of my Rogue
Thanks in advance for your advice
Bill Lewis
Postby ImStricken » Tue Jun 05, 2012 6:10 am
Bill Lewis wrote:I have a 2008 with 52k on it. Have a hitch and have doen some light towing of a small landscape trailer with my motorcycle and some household items. Just to clarify. Having just moved to Cape May NJ the nearest Nissan dealer is 40 miles away. There is a shop her recommended by a few friends. They say they can get the fluid from the Nissan dealer and drain and refill the CVT but don't have the equipment to do a flush. Is this OK or not. I don't understand the advantage of flushing the CVT if your changing the fluid. a little old fluid left in there can't hurt that much can it??
yes, your 100% FINE with just a drain, and refill.
the only reason i was suggesting the original poster to get a FLUSH - is because he was not sure what the transmission was filled with(possibly wrong fluid). i have a history with that user, he purchased a wrecked & salvaged rogue that he was rebuilding.
i too tow a motorcycle with mine, and will be doing a 60,000 drain on the tranny. but i have to ask you an important questions though = have you changed/drained your transfer case & differential yet? if not = DO IT! its very-very important to drain those as well. if you are handy i did 2 write-ups on how to do those two services right in your driveway, and its relatively simple. interested for the links?
ImStricken
'08 Nissan Rogue SL
'07 Suzuki GSXR600
'06 Yamaha R6
Postby Bill Lewis » Thu Jun 07, 2012 5:55 pm
Thanks for the reply. I'm at 52K and at about 60K I will have the drain/fill, Transfer and diff. all done. Some say leave it all alone but I'm a preventive matenance guy.
I've also never had brakes done and at this mileage is that normal. Should I just have them done because of the mileage?
Ride safe
Bill in NJ
Bill Lewis
Postby ImStricken » Thu Jun 07, 2012 7:17 pm
Bill Lewis wrote:Thanks for the reply. I'm at 52K and at about 60K I will have the drain/fill, Transfer and diff. all done. Some say leave it all alone but I'm a preventive matenance guy.
Ride safe
Bill in NJ
ya, some say leave it alone - but im like you. prevention = less problems.
id change the tranny fluid at 60, and then never change it again. as the tranny gets older - the grit actually helps things grip. older parts are a bit worn, so installing fresh slippery fluids ends up causing them to slip.
and regarding the brakes; they really need to be judged by how you drive, not distance. i always, almost every weekend, spend time in NYC with the misses so i end up wearing mine down constantly and quickly. some folks, can drive 50k on original pads! unreal, but its been done. it also depends how fast you drive, because those who drive fast, have to brake harder. id have them checked, and maybe re-checked by a 2nd shop. most shops know if you dont know how to check on your own, you wouldnt know if your being lied too ;)
i did a good write-up if your tool-friendly.
ImStricken
'08 Nissan Rogue SL
'07 Suzuki GSXR600
'06 Yamaha R6
Return to Rogue Forum
