P0325/0304 Knock Sensor
P0731 A/T 1ST Gear Function
P0732 A/T 2ND Gear Function
P0733 A/T 3RD Gear Function
It was expected that the first code caused the last 3.....
Replaced the knock sensor and cleared the codes - all appeared to be well but the CEL came on the following day
Now when doing a scan the P0325/0304 Knock Sensor code is no longer stored but the gear ratio codes are still showing.
The car does seem to be reluctant to change up at times but once the car has warmed up it seems to be fairly consistent but not as smooth when changing (this is an auto box of course) as I'm used to.
What I've been doing as a work around is to rev the car then take my foot off the gas to allow the car to change up - seems to work most of the time - however, if I just keep the foot down it'll rev out before it changes...
Any ideas?
Solution!
Well, despite not having a TPS error code (or obvious TPS problems) - the TPS was showing readings well out of tolerance for the car.
Just changed the TPS today - which is the second TPS the car has had since owning the vehicle - and now the gears are changing perfectly!
It's taken a while to get to the bottom of this but it was a very cheap and easy fix now that it's over!
