I have been getting a lot of PM's requesting pricing on custom cluster setups and other custom fabrication. So I thought it would be beneficial to myself and customers to make a for sale thread with some pictures, options and base pricing. That way I can simply guide most inquiries here.
Clusters, Molded HUD and Center Vent Gauge Plates
All of my clusters are one-offs, made-to-order. I have only had requests for S13 clusters... so that's all I have made. Please feel free to request a cluster besides an S13, and we can discuss it.
***NOTE: I do NOT sell any of the actual electronics; gauges, HUD's, controllers etc.***
S13 Cluster Base Price: $100
- Customer supplies OEM S13 cluster and aftermarket gauges.
- I modify the OEM cluster, black front and white back, to accept the new plate.
- I fabricate plate for your gauge setup. Usually 4-5 52mm or 60mm gauges.
- My standard finish with a nice texture coat, followed up by a satin/low gloss black.
- Gauges are flush mounted... so not the simple drop in from the front.
- Wet sand and polish clear plexi front inside and out: $25.
- Integrate OEM turn signals: $75.
- Other custom options can be discussed with me... LED indicators, custom finish etc.
Examples:
The following picture also displays the optional $25 polishing on the front OEM plexi:
Molded HUD On OEM Steering Column Shroud: $350
- Customer supplies Defi VSD Concept X HUD (now discontinued but still available online).
- Customer supplies top and bottom of steering column shroud.
- HUD modified for molding.
- HUD molded into top half of shroud.
- My standard finish with a nice texture coat followed up by a satin/low gloss black.
- Bottom half of shroud finished in same fashion to match top half.
- Simple bolt back onto steering column, no modifications needed to vehicle.
- The tilt column will still have a full range of motion.
- The HUD is still visible even in direct sunlight.
- Note: The Defi HUD will work as a standalone unit and will display speed and RPM.
S13 Center Vent Triple Gauge Plate 52mm: $75
- Customer supplies (3) 52mm gauges.
- Back Plate for (3) 52mm gauges.
- Includes angled rings for better viewing.
- Plate will have OEM quality fitment.
- Gauges and rings will be mounted to plate.
- Mounting system for gauge plate. With this option, you could hang from the gauges: $35
Optional mounting system:
Other Custom Fabrication
Please let me hear your ideas if you want me to tackle some other interior fabrication.
Some examples,
S13 map light modified and molded for a turbo timer:
S13 cluster surround gauge. This one is popular when combined with one of my clusters for the fuel level. However, you could put any 52mm digital gauge there. Surround is modified to accept the gauge and a smoked plexi front to hide the gauge, except when lit up:
NOTE: The S13, S14 and S15 sending units all read around 5 ohm full and 80 - 90 ohm empty. The closest you will get with an aftermarket gauge is 90 ohm full and 0 ohm empty. Which simply means the gauge will read backwards. So depending on the digital gauge, it's either going to read gallons used or percentage of fuel used. As opposed to gallons left or percentage of fuel left. Not that big of a deal in my opinion. I recommend the Cyberdyne unit, as they make it in red, amber, green and blue. It also has a black bezel which is needed in this type of install. They do make them with a silver bezel, so make sure you order the correct one.
http://www.summitracing.com/parts/CYB-A036E060N/
Glove box control center plate:
