toki »
https://forums.nicoclub.com/toki-u4152.html
Thu Jul 08, 2004 2:55 pm
Ok...
So I'm not understanding so well, is the point of a getting a bigger MAF is to increase the range of air it can detect (example: getting a z32 MAF to operate on 1-8v versus a stock MAF operating on 1-5v)
Or is it to reduce the output of the MAF based on the volume of air? (example: 50CFM of air intake sending 2.0v on a stock MAF, but 1.5v on a Z32 MAF)
please note, all numbers are strictly just there as numbers, I don't assume them to be accurate, neither should you.
Now, depending on the answer, for the higher operating range, why doesn't the ECU freak out at 5v just like it would with a stock MAF -- and if the answer is for reduced voltage, wouldn't that result in the ECU sending the wrong injector pulses to the ECU thinking there is less air?
I'm asking these question based on someone saying that with an upgraded MAF, you still have +/- 50% adjustability with an S-AFC, so to me that assumes there is no compensation required for the bigger MAF itself.
Sorry for the long post, but I like to be detailed, I've found it gets you better answers. Thanks.
