Bee*R rev limiter on KA24DE 92 240sx
Yanior
Car: 92 240sx HATCHBACK
Alrite ladies and gentle men..I've spent quite some time trying to find and actual Diagram of how t install a Bee*r rev limiter on a 92 240sx hatch..And i've looked at every way possible that comes up on google and on allof these FORUMS but none of them worked for me..So i made my own little DIAGRAM of how I Installed mINes and made it work. SO here goes for all of you trying to iintall it on a KA24DE.
Why I DID THIS? Baa BAnnnG!!!Flames,Protection for my engine(HEAVY FOOT)and Attention!! ohh and might be helpful later on when i get a TURBO to build up boost..Well thats what i've read around here..
Modified by Yanior at 6:41 PM 10/29/2008
Modified by Yanior at 7:12 PM 10/29/2008
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
nice..way to go..the diagram makes it way simple..allthou i would sugest a write up why ya did the install in the foirst place for the beginners on the forum..2 thumbs man.
eclipse2001gt
Car: 240sx 350 small block
I would have just pulled all the sensors off the trans and cut the yellow and green wire. Would have saved money.But to all there own.
sloweighty
Car: sileighty
eclipse2001gt wrote:I would have just pulled all the sensors off the trans and cut the yellow and green wire. Would have saved money.But to all there own.
how would cutting this wire save you money (please explain)
TrueDrifter
got a question why do you get popping and flame from the muffler?? Is it because your revs are high making the engine Lean and the Bee*R rev limiter is putting more gas in to make it be rich??
LayNLow240
Car: 92 240 coupe
Because the bee*r cuts ignition, not fuel. Thus the extra fuel ignites when it comes into contact with fresh air if it is hot enough. Which for a na ka means a glowing hot manifold.
jpnissans13
Car: 1991 s13
hey can you post that diagram up one more time?
im having trouble with my bee r.
[email protected]
Car: 240SX SE
I know this post is old but my friend and i are trying to connect the bee-r to a 95 and the color combos are different for the s14 any help please?
eclipse2001gt
For one you don't have to worry about wiring any thing. Unless you want to add a switch in there to turn the rev limiter on so that you pass smog test. But then after you do that you can have a switch that can be flipped off or flipped on any time you want it to be on or off. And when you do cute that wire it turns off one of the o2 sensors so your exhaust smells like rotten eggs.
3 bucks for a switch
4 bucks for wire
10 to 15 mins of your time and 7 bucks for parts and your done.
Sorry for taking so long to respond to you. I just got back into the 240sx seen again and very happy to be back.
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
Well welcome back! It's kind of a ghost town round here nowadays tho.
slidewaysftw
Car: 1993 240sx s13 fastback
For some reason I can't see the picture I can see half of the pic it says this picture is private on photo bucket
