As the title says, I've installed BC Stage 2 cams in my KA, with correct OEM timing (checked, double checked, and triple checked) on a previously running engine. Let me reiterate that part... The engine was running PERFECTLY prior to the install. The cams were installed as per BC's instructions: cut the shank for the FWD distributor off the intake cam, and switch the intake and exhaust. They look completely correct, at #1 TDC compression the intake lobe is at about 9:30 and the exhaust lobe at about 2:30, just like stock cams. Now the engine cranks over all day long but will not fire. Sounds very odd too, like the cams are out of timing. So as I said I checked and checked again and all the timing marks are perfect. Threw a compression tester on it the other day, the engine holds absolutely NO COMPRESSION whatsoever. The gauge will climb to about 30-40 but falls back to zero with every revolution of the engine. This seemed odd to me so I thought maybe the compression gauge was defective. Threw it on the daily beater which obviously runs and drives and it reads just fine. I'm completely stumped here. It's got to be something stupid and easy to fix. It's not like the engine could have blown a head gasket or bent every single valve while sitting there not running for two weeks... Has anyone else had an issue like this with BC Cams? I really don't want to be that guys who has to haul his half done project down to the shop to pay someone to make it run, but I've got limited diagnostic equipment at home and there aren't many things left that I can do.
Just for reference, here's a pic of the cams as they were installed, and nothing was changed with the timing between this pic and the first startup attempt.
