I don't know the exact answer but I heard it goes off at 25mph. I assume you traveled at least that fast, right?RedRogue wrote:When I switch the AWD Lock to on, the indicator light always stays on no matter what speed I drive at. According to the manual the light is supposed to go off when driven at at a high speed. I drove mine for around ten minutes at various speeds and the light never turned off. To turn it off I either have to push the lock switch again or turn the ignition off to reset it. Is the manual wrong? Does everyone's work this way too?
YOUR LIGHT WILL STAY ON, BUT THE REAR DIFFERENTIAL WILL DISENGAGE WHEN REACHING 6MPH. ITS GOOD ONLY WHEN STUCK IN SOMETHING AND YOU CANT GET OUT. ONCE YOU REACH A CRUISING SPEED OF ABOUT 6MPH THE SYSTEM AUTOMATICALLY GOES BACK INTO FWD NO MATTER WHAT. YOU WERE NOT "LOCKED" IN AWD EVEN WITH THE LIGHT ON.RedRogue wrote:When I switch the AWD Lock to on, the indicator light always stays on no matter what speed I drive at. According to the manual the light is supposed to go off when driven at at a high speed. I drove mine for around ten minutes at various speeds and the light never turned off. To turn it off I either have to push the lock switch again or turn the ignition off to reset it. Is the manual wrong? Does everyone's work this way too?
THE AWD INDICATOR COULD BE DUE TO YOU HAVING A DYING BATTERY. I JUST EXPERIENCED THE SAME EXACT ISSUE. OR YOU COULD HAVE A AWD PROBLEM THAT NEEDS ADDRESSING. YOUR AWD IS A DIFFERENT INDICATOR LIGHT THAN THE ORIGINAL POST IS ABOUT. THEIR LIGHT IS A "AWD LOCK" LIGHT THAT IS TURNED ON VIA BUTTON ON THE BOTTOM LEFT OF THE DASHBOARD BY YOUR LEFT KNEE.had2seeu wrote:Just started happening to my Rogue as well, the AWD light on the dashboard automatically comes and stays on even after driving it over 50mph...I have to stop the car and turn off the ignition to get it to not appear...Should I bring it to the dealership to get this addressed?
excuse my ignorance on the subject but I have been confused about the AWD on the Rogue, from your reply above, thats my understanding of how the Rogue's AWD works without hitting the "Lock" button, I guess my question is what's the difference between "Lock mode" and "Auto mode" if both mode goes to FWD when the car reaches 6MPH?ImStricken wrote: YOUR LIGHT WILL STAY ON, BUT THE REAR DIFFERENTIAL WILL DISENGAGE WHEN REACHING 6MPH. ITS GOOD ONLY WHEN STUCK IN SOMETHING AND YOU CANT GET OUT. ONCE YOU REACH A CRUISING SPEED OF ABOUT 6MPH THE SYSTEM AUTOMATICALLY GOES BACK INTO FWD NO MATTER WHAT. YOU WERE NOT "LOCKED" IN AWD EVEN WITH THE LIGHT ON.
your correct. we start out from zero mph to 6mph in awd, and then it turns to front wheels drive. i heard that using the lock switch will allow you to travel up to 15-25mph in a straight line ONLY FORWARD but that's unconfirmed by anyone. every mechanic says a different story. personally, wouldnt touch this switch unless your stuck and you think it might help you - or you are driving through really really rough snow/sand/mud and you wanna try it. otherwise, i think its useless as the system will detect wheel slip as it is, and engage AWD on its own.Nick2010 wrote:excuse my ignorance on the subject but I have been confused about the AWD on the Rogue, from your reply above, thats my understanding of how the Rogue's AWD works without hitting the "Lock" button, I guess my question is what's the difference between "Lock mode" and "Auto mode" if both mode goes to FWD when the car reaches 6MPH?ImStricken wrote: YOUR LIGHT WILL STAY ON, BUT THE REAR DIFFERENTIAL WILL DISENGAGE WHEN REACHING 6MPH. ITS GOOD ONLY WHEN STUCK IN SOMETHING AND YOU CANT GET OUT. ONCE YOU REACH A CRUISING SPEED OF ABOUT 6MPH THE SYSTEM AUTOMATICALLY GOES BACK INTO FWD NO MATTER WHAT. YOU WERE NOT "LOCKED" IN AWD EVEN WITH THE LIGHT ON.
I never really done any test about AWD LOCK and VDC switch, but one day I'll test it I don't even know the procedure if I should hit those switch while on the move Or from a complete stopImStricken wrote: your correct. we start out from zero mph to 6mph in awd, and then it turns to front wheels drive. i heard that using the lock switch will allow you to travel up to 15-25mph in a straight line ONLY FORWARD but that's unconfirmed by anyone. every mechanic says a different story. personally, wouldnt touch this switch unless your stuck and you think it might help you - or you are driving through really really rough snow/sand/mud and you wanna try it. otherwise, i think its useless as the system will detect wheel slip as it is, and engage AWD on its own.
Edit: When driving in deep snow where you are likely to bog down, the key is turning off the VDC, not turning on the AWD lock.
VDC = traction control. keeps the tires from slipping. turn it off, and you will have wheel spin on slippery area's. since the rogue has a weak engine, i dont see any wheel spin unless on ice.Nick2010 wrote: I will conduct my own test when we get snow this winter and will record too.
